It is currently Sat Nov 21, 2026 2:37 am
 Post subject: 77 head on 66 block
PostPosted: Mon May 26, 2003 6:27 pm
Will a 77 head bolt right onto my 66 block?
PostPosted: Mon May 26, 2003 6:29 pm
Yep. No problem.
65' Dart. A work in progress..
______________________
Joe
PostPosted: Mon May 26, 2003 7:17 pm
It will bolt on, but if I am not mistaken, you will have to use the rocker assy. off of the 77 head because the bolt closest to the fire wall is much smaller and the hole in the shaft is different.
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
