It is currently Sat May 30, 2026 5:10 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Thu Oct 15, 2009 12:27 pm
Car Model: 1964 Valiant V200
Want to rebuild the Valiant motor with a moderately hot combo, big overbore, bigger valves, mid cam, loose converter, 10:1 compression, etc. Low-ish redline with the stock 3-speed 904 behind it.
I can't decide what to do about the intake though. I want one of the vintage looking intakes, which pretty much leaves me with the Cain/Lynx/Redline 3xSU manifolds and the Offy 2x1 barrel.
Any others? I like the aussiespeed 2bbl one, a Holley 500 should be pretty cheap on there and the long runners mean it probably works pretty well with the stock 3-speed. However I worry it looks too 'new', no patina. I'd lik something that looks vintage still. Hmmmmm....
PostPosted: Thu Oct 15, 2009 12:37 pm
Unless I am mistaken, Clifford and Offy intakes have been around at least since the 70s, if not earlier.
PostPosted: Thu Oct 15, 2009 12:42 pm
I'd run an AFB on an Offy. That's plenty vintage (mid 60's) and it works.
PostPosted: Thu Oct 15, 2009 12:58 pm
Yeah, Offy intake is one choice. Especially if I can find a used one with a little patina.
Aren't AFB's overkill for most slants?
PostPosted: Thu Oct 15, 2009 1:17 pm
Car Model: Toad Wagon
A point about the Lynx,
The Lynx SUx3 is very narrow in the runners (roughly 1 1/4sq" area cross section at mid-point, down from the slant's 1 1/2" average in the head) and tends to have a Mays type "squirt" effect on the valve closing rebound wave going back up the runners that reaches and disrupts the jets at rpm. Depending on the valves and the carbs this can be as low as 3000.
My present (temporary, but working) solution is 7" of 1 3/4" stack above the carbs (mine're HIF6's), keeping the "pressure head" above the jets stronger than the problem. It's good for about 5500.
If I can't hog out the runners enough to contain/defeat the problem I'll likely resort to cobbling up my own (longer, or at least larger) manifold, another possibility you might consider. Home brewed manifolds were around long before the aftermarket ones.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Oct 15, 2009 1:30 pm
Thanks for the info..
What about the Redline DCOE setup? That seems like it would be waaaaaaay big for a slant with an auto though.
PostPosted: Thu Oct 15, 2009 2:14 pm
40 mm DCOE's should be perfect for a mild/medium Slant.
PostPosted: Thu Oct 15, 2009 4:18 pm
Poser
Patina can be created. Talk to the rat rod guys. What about a hyper-pak repo? Early 60's stuff. Love the vintage look!
PostPosted: Thu Oct 15, 2009 4:30 pm
I also vote for the Offy intake, but there are other good ones out there.
Maybe you can adapt an early sixties air cleaner to whatever carb you decide to use.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Oct 15, 2009 4:41 pm
That is what I was thinking. Some kind of vintage-looking air cleaner on a rebuilt AFB on a used offy intake.
That's the cheap way to do it.
Ultimate way would be 3 used 40 DCOEs on a used Cannon intake.
PostPosted: Thu Oct 15, 2009 5:05 pm
Offy intake, dig up a Carter AFB 400 CFM carb (if you find one and don't want, kick it my way),top it with an old hillborn style air cleaner sticking through the hood.
PostPosted: Thu Oct 15, 2009 5:13 pm
no holes in the hood, LOL not cutting or welding anything on this car.
PostPosted: Thu Oct 15, 2009 5:32 pm
I thought all intakes SUCKED..........
:twisted:
PostPosted: Thu Oct 15, 2009 6:25 pm
:twisted:
If they're working they do. :wink:
PostPosted: Thu Oct 15, 2009 6:27 pm
Car Model: 1968 A108 225/3 on the tree
they do suck. . . .they sucked u into this thread. . . .
they sucked me in too!
D~~~!
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
2003 Ford Ranger XLT extra cab
1997 Geo tracker(Suzuki Sidekick)
Users browsing this forum: Bing [Bot] and 13 guests
