It is currently Tue May 12, 2026 2:34 pm
 Post subject: Choke Problems
PostPosted: Sat Oct 17, 2009 4:34 pm
Car Model: 1986 D100 /6 A833od shortbox
Hello all-
I have an largely unmolested 86 Ram with a non feedback 1945 Holley. I replaced the carb to manifold gasket recently, and since have been having problems with the choke. Initially, I couldn't choke at all, and cold starts were tough and time consuming. I replaced the linkage between the, excuse me if this is the wrong terminology-the idle cam and the thermo thinger in the pyramid on the manifold, and that seemed to remedy the problem...until today. Same thing all over again. Any guidance/advice is greatly appreciated.
Thanks
Josh
86 D100 225 one barrel 4 spd
 Post subject: Re: Choke Problems
PostPosted: Sat Oct 17, 2009 4:37 pm
Hello all-
:lol: Good description. Your answer lies in this article: http://www.slantsix.org/articles/choke- ... adjust.htm
PostPosted: Sat Oct 17, 2009 6:55 pm
H'mm. You may have missing or incorrectly-connected linkages, or the choke thermostat — that's the sheetmetal box bolted to the exhaust manifold tower with a rod running up to the top rear of the carburetor — itself may be faulty. Me, I tend to remove the '73-up choke setups and instead install one of the Electric choke kits.
PostPosted: Sun Oct 18, 2009 7:31 pm
Reed- Thanks for the link
Dan- This works for you? I was considering a manual choke run to the cab, but this looks more interesting (and maybe less of a headache)
PostPosted: Mon Oct 19, 2009 8:47 am
No, not at all, but oddly enough, I keep doing it! :lol:
(Yes, it works.)
PostPosted: Mon Oct 19, 2009 9:35 am
Point taken Dan. They say I shouldn't keep hitting my head with this hammer, but what do they know. Thanks for the advice. Would I be correct in assuming that I wouldn't have to pump the gas before cold start up any more if I switched to the electric choke? Is install pretty straight forward?
I found that the linkage on my choke is catching ever so slightly on the sheetmetal housing for the thermostat. I have made the necessary adjustments and everything is working as it should. Thanks again Dan and Reed for you guidance.
PostPosted: Mon Oct 19, 2009 12:51 pm
If you go to an electric choke you will still need to pump the gas once (or even only 1/2 of once) to allow the choke to close and the fast idle cam to set.
PostPosted: Mon Oct 19, 2009 7:17 pm
just like reed says you wont hardly have to pump at all(one pump or a partial one). i have an electronic choke kit from the link dan provided and mine works great. i dont mind manual chokes myself but i dont mind being efficient on the other hand either. wouldn't be a bad choice to snag one up.
Users browsing this forum: Bing [Bot] and 9 guests
