It is currently Fri Nov 20, 2026 1:22 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Oct 18, 2009 6:42 pm
They used BOTH an 8-1/4 (just like what we are all used to) OR teh Dana 35 in Cherokees; but again you need 97-older to get the correct splines. I dont believe they ever used an 8-1/4 as a front diff; so that one is moot; but if so as already was mentioned, if they had the gears would be reverse cut.
PostPosted: Tue Oct 20, 2009 4:20 am
Before taking apart yard rear (at home) measure backlash. It should help you with setup to get the used gears to run quite.
