It is currently Mon Aug 10, 2026 9:12 am
PostPosted: Thu Oct 22, 2009 9:12 pm
Car Model: 1962 Lancer 770
Hi guys,
Looking to buy a new timing set and damper for my 64 block that I am building up. I was trying to decide between the JP set and the Cloyes double rollers (can't find a Romac/Rollmaster which I think is the same as the JP?). I remember when I put my current hughes double roller in, that people thought it was easier to simply drill out and bush it than deal with the "adjustable" JP set.
Am I remembering that right? I'd appreciate some advice there.
Also any harmonic damper recommendations?
thanks
MJ
PostPosted: Fri Oct 23, 2009 5:03 am
Personally, I can't be bothered with the multi keyed crank sprockets. I think it is easier to drill the cam sprocket and do the adj that way. I have a set, of the multi key, in one of my engines, and wound up drilling the cam sprocket on that, since it was such a pain removing the crank sprocket and reinstalling it (semi-tight fit, needed a puller).
As for the damper, I sent a e-mail to a NOS vender I have delt with. He used to have some NOS late style (6 spoke dampers). I purchesed a couple from him. Will let you know.
PostPosted: Fri Oct 23, 2009 6:11 am
You have a PM, about the damper. If you buy it, you will need to make a new timing mark, unless you use the later timing cover.
PostPosted: Fri Oct 23, 2009 11:40 am
I am thinking I actually have a later timing cover on my other motor, but I'm sure I dig one up. Are there any other issues since I am used an early forged crank, not a cast one. Besides the design of the wheel with more spokes and space, are there any other differences?
Thanks Charlie!
MJ
PostPosted: Sat Oct 24, 2009 6:12 am
Try finding one of the Aussie Romac balancers. Very nice parts and can be had in aluminum or steel. I bought one for my 318 and it was very high quality. They used to be available for slants, but it's been a while since Ive looked.
-James
PostPosted: Sat Oct 24, 2009 8:01 am
Romac:
http://www.pentastarparts.com.au/sunsho ... tail&p=507
That price is probably in AUS $. At current exchange rates, I think that it would be about $30 less in US$, but then there's shipping.
obliquely-inclined state of mind
PostPosted: Sat Oct 24, 2009 10:14 pm
I will see what I can scrounge up on romac, may be a touch more than I want to spend for my damper ;)
MJ
PostPosted: Sun Oct 25, 2009 9:45 am
Aren't those 6-spoke Mopar dampers for cast crnaks only?
What do you think about using one of those Mopar 440 RB dampers and adding a 1 groove pulley on the front?
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
Users browsing this forum: Bing [Bot] and 5 guests
