It is currently Thu Oct 01, 2026 1:02 am
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Oct 22, 2009 2:19 pm
The 1965 Dart is on a 111" wheelbase, yes (except the station wagon model, which is on 106")
PostPosted: Thu Oct 22, 2009 4:10 pm
Thanks Dan! Mopar subframe connector here I go!!!!!!!
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Fri Oct 23, 2009 4:19 am
Product Description
[quote]This handy prefabricated connector package lets you tie the front and rear frame longitudinally on all "A" or "B" bodied drag cars. Package includes two connectors, brackets and necessary mounting hardware.[/quote]
Polara1974, check this [url=http://chucker54.stores.yahoo.net/framconpac.html] page [/url] as it lists the welded connector ( ‘67 – ‘69) as a separate number for what ever reason. I have not been under a pre ‘67, or post ’67 A Body for a comprehensive look-see to be able to pass judgment as to how these bars would fit another year build different from my 1967. 108â€￾ wheel base is for the later Duster stile two door cars. Give’em a call; the folks at Mancini are always helpful.
I suspect these bars will fit your 1965. Have a cut-off wheel grinder handy when you decide to start the project, and be prepared for a bit of trial fitting. Also I needed to use four longer bolts than what was included with the kit.
PostPosted: Fri Oct 23, 2009 10:08 am
PostPosted: Fri Oct 23, 2009 3:01 pm
Car Model: 1962 Lancer 770
See I've been curious about this for awhile, since I have that 106" wheelbase, should I order 108 or 111? since I'm going to probably have to cut them to fit anyway...
Or just make my own, which are guaranteed not to fit right ;)
MJ
PostPosted: Fri Oct 23, 2009 8:36 pm
fire up the miller welder, and make your own! they are not that hard!
When you come down here in a few weeks, you can see mine. And if I can do it with my fab skills, anybody can.
G
PostPosted: Fri Oct 23, 2009 9:29 pm
You've got a 106.5" wheelbase. The '63-'66 Valiants (+'63-'66 Dart wagons) had a 106" wheelbase.
PostPosted: Fri Oct 23, 2009 9:50 pm
i stand corrected. =)
 Post subject: Tried both
PostPosted: Mon Oct 26, 2009 3:09 am
On my rustbucket ragtop, I used some free 2X2" tubes 3/16" thick: weighed a ton! Then we welded on perches and installed a Jegs 4 point roll bar. It gave me a place to attach shoulder belts, and the car feels like a brick house. On the fastback, which is actually in nice condition, we used the US Cartool ones. They look a lot nicer, almost like they came with the car. Also improved the ride immensely. The main difference is that the suspension, which was always super tight and harsh, softened up, almost like the suspension is doing more work.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Mon May 23, 2011 2:45 pm
Bumpity bump. :D
 Post subject: Subframe Connecters
PostPosted: Tue Jun 14, 2011 8:52 am
What excellent timing, I just finished a write up on my webpage about installing subframe connectors on my own Valiant! 8)
Quick, Cheap and Dirty Subframe Connectors for the Mopar A-body
Scott - waywardgarage.com
Why is the rum always gone? Image
