It is currently Wed Nov 18, 2026 11:29 am
 Post subject: Correct pinion angle
PostPosted: Thu Oct 22, 2009 7:53 pm
Is there a way to set the pinion angle without the Transmission and driveline not in the car? I am going to mount my narrowed 8 3/4 rear this weekend and would like to tack the spring perches in place, but the engine and transmission are not in the car and won't be for a while. Can I set the angle in relationship to the rocker panel or some other landmark? Or do I have to wait until everything else is in place. I see conflicting measurements on the correct angle and how to measure it. Any help would be appreciated.
This car is a 65 Valiant race car, with 4-speed transmission.
Rick
 Post subject: Re: Correct pinion angle
PostPosted: Thu Oct 22, 2009 9:19 pm
No. You have to wait til the engine, trans, and driveline are installed.
The FSM contains a good procedure.
PostPosted: Fri Oct 23, 2009 7:15 am
Rick
I feel for you I once tried it with the engine and trans "just sitting in there" but not bolted tight. I was OFF by a mile.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Thanks
PostPosted: Fri Oct 23, 2009 2:26 pm
Not big deal. I'll bolt it in without welding the perches on (or maybe one small tack) and then I will be able to set it on the ground and move it around. I'm seeing pinion angles of between 4 & 8 or more. Is one end of the spectrum better fopr a race car setup than the other? Sorry Dan I don't have a FSM. That will be on my wish list for Christmas. :)
Rick
PostPosted: Sat Oct 24, 2009 7:34 am
Rick
I just think that the angle needs to be correct for your setup more than what angle your running.
IMHO
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Oct 24, 2009 3:22 pm
8* down was usually reserved for a really fast leaf spring 4 speed car. Most milder setups will live long and happy with 2-3* down.
My Valiant was happy with 0*. :shock:
 Post subject: -
PostPosted: Sun Oct 25, 2009 6:36 pm
I agree with slantzilla,4-8 degrees is for full race cars,anything more than 2-3 degrees will cause the driveshaft to hum on the street.
PostPosted: Tue Oct 27, 2009 1:32 pm
It looks like I'll shoot for 2-3 degrees down. I just didn't know if a 4-speed and slicks would change the angle needed.
Thanks for the info, Rick
