It is currently Tue Oct 13, 2026 9:50 pm
 Post subject: Engine gasket set
PostPosted: Thu Oct 22, 2009 6:44 pm
Hello ,
i am looking for a good gasket set for my rebuild of my 1987 Dodge B150 225 slant six 3.7 3 spd auto ~~ i was looking at remflex but only saw intake & exhaust ~~ also looking at aussie speed but didn't see a gasket set there either ~~ am i missing something ?? i want to use a real good gasket set ~~ thanks to you all & this forum i learn allot just reading the info you all put out ~~ this is a great forum and some sweet looking motors & rides also probably going to do a trannie rebuild also actually i plan on going thru the whole van top to bottom inside & out we will see :D
 Post subject: Yep...
PostPosted: Thu Oct 22, 2009 7:03 pm
You have to buy a Fel-pro gasket set for the full engine, then just don't use the riser and manifold gaskets...and then buy the Aussie or Remflex gaskets for those specific items... For pre-1980 engines the set is KS2103... and the 1981-1987 crowd that just needs that odd valve cover gasket...is KS2116.
PostPosted: Sun Oct 25, 2009 5:14 pm
Thanks for your help :D
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 18 guests
