It is currently Sun Oct 11, 2026 8:42 pm
PostPosted: Thu Oct 29, 2009 8:00 pm
Does anyone know where I can purchase a choke pull off for a Holley single barrel carb? Model # 1920 and List #3280. Holley no longer carries this choke pull off.
Thank you,
Herr Otto
PostPosted: Thu Oct 29, 2009 9:33 pm
I have several of these new on the shelf (send me a PM) but you ought to be able to find one locally. I have no trouble pulling one up at rockauto.com, for example.
PostPosted: Fri Oct 30, 2009 8:09 am
I have checked, Holley, Advance, Auto zone, Oreilleys, NAPA and Car quest. I will check Rockauto.
Thank you,
Otto
PostPosted: Fri Oct 30, 2009 8:19 am
I just called Rockauto and they do not have it. Do you have a part #?
Thanks,
Otto
PostPosted: Fri Oct 30, 2009 10:43 am
You called RockAuto? :shrug:
C'mon, dude, let your fingers do the walking. www.rockauto.com . Took me three clicks to find the choke pull-off; I'm sure you can do the same.
PostPosted: Fri Oct 30, 2009 11:03 am
I called rockauto, and they said their choke pull offs are listed by application and there is none listed for a 1965 Dodge Coronet. Then I asked can't you look it up by Carb # and they said only if I have the choke pull off #. If the guy who works there cant find it I certainly wont.
Otto
PostPosted: Fri Oct 30, 2009 11:16 am
It remains a mystery to me how I manage to find parts on rockauto.com that are invisible to others, but here y'go:
AIRTEX Part # 1C1171, $11.81 .
PostPosted: Fri Oct 30, 2009 4:44 pm
Thank you. The part looks correct, but is says it fits Dodge Coronets 1971-1973.
Thanks again,
Otto
Users browsing this forum: No registered users and 17 guests
