It is currently Sat Jun 13, 2026 9:27 am
Post new topic  Reply to topic  [ 73 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Arp
PostPosted: Wed Oct 28, 2009 5:51 pm
nice deal here,
placed my order this evening, easy transaction, the main studs are in stock ,,the rod bolts and head stud sets are on back order, should be available to ship mid November.
Stan gave me the number for the cam bolt,, 155-1002.
PostPosted: Thu Oct 29, 2009 6:32 am
I guess I got my order in just in time. Ordered my head studs, and rod bolts, yesterday, and they were going to ship same day.
You guys are a bad influence. Coming up with all these good deals, and forcing me to build a "good" engine, instead of another e-bay/swap meet engine. :lol:
PostPosted: Thu Oct 29, 2009 2:02 pm
Thanks all - I ordered my junk today - They were outta Head and main sets, but I should see the cam bolt by the end of the week. The other stuff is backordered and should be here in 2 weeks.
I did not get rod bolts because I have a set already.
Thnaks!
PostPosted: Thu Oct 29, 2009 4:11 pm
Does anyone know if the manifold studs and washers come with the head stud kit, if not do you have a number for a manifold kit.
thanks :D
Jim
1964 DART G.T. 225
2008 JEEP WRANGLER UNLIMITED
1950 SCHWINN PHANTOM
PostPosted: Thu Oct 29, 2009 4:23 pm
If the Slant rod kits are out of stock you can order a set for a 340 and have 4 bolts left over. :shock:
PostPosted: Thu Oct 29, 2009 4:29 pm
Poser
Head and main studs came today! Yabadaba...doooo! :D
PostPosted: Fri Oct 30, 2009 10:31 am
Heads studs and rod bolts just arrived
 Post subject: Jlc 64...
PostPosted: Fri Oct 30, 2009 12:26 pm
The triangle washers are still available from Dodge/Chrysler dealership, part # 3751 636. Be prepared - they are somewhere around $2.70 each.
Brass nuts - Dorman Part # 680-001 or 849-001 (same nut, sold to stores in different packages)
New studs (Grade-eight) - Dorman Part # 675-093
You can read all about manifold mounting HERE if you haven’t already.
Danny
PostPosted: Fri Oct 30, 2009 7:46 pm
Bee aware if you are useing main studs they recomend align hone or bore mains,I went with the 2.75 Arp main bolts to try to stay away from this.Will bee dropping crank in block next week to see how it feels.I tried to order from Summit but they were out of stock.Ordered direct from Arp and got head studs and main bolts the next day $122.I do get a 15% discount because I have a shop and have ordered in the past.Guzzi Mark
PostPosted: Sun Nov 01, 2009 3:16 pm
Car Model: 1962 Lancer 770
we appreciate your legwork, I gotta place a large order at Summit anyway, so I guess this will help me do it..
MJ
PostPosted: Sun Nov 01, 2009 3:42 pm
Poser
MJ - large order -what are you up to ? If you don't mind me asking. Thanks for the kudos! I consider you the godfather of the group buy (Erson Cams)! :D Once I figure out how a cam works I may order! :shock: Lou has tried to tutor me but he may have to draw me a picture. Thanks again, Wayne.
PostPosted: Sun Nov 01, 2009 4:41 pm
I'm with you, sometimes there are just missing pieces that I don't get until hearing it about 25,000 times. Lou is a patient guy luckily ;)
What am I ordering? all the junk for my new buildup. motor is at the machine shop now, but I'm having to pick up a few "odds and ends" that somehow end up being $$$ =)
MJ
 Post subject: group buy?
PostPosted: Sun Dec 12, 2010 7:17 pm
Is the group bye still on?[/b]
