It is currently Fri May 08, 2026 7:51 pm
PostPosted: Fri Oct 30, 2009 6:31 pm
Ok i'm about to do some wiring on the slant that i'm putting my 1951 International pickup. So I can get it running before I put it in the truck. What I need is a wiring diagram for the starter solenoid. Pic. would be very helpful to. The motor is a 1978 Plymouth slant super six (225). Any and all help will be appreciated.
Thanks for any help . :?:
flipfloppop
PostPosted: Fri Oct 30, 2009 10:53 pm
6 Pack Dart
The solenoid Relay
S = starter from ign switch
G= neutral safety switch
Sol= small wire at starter
B= main feed to starter and to battery
PostPosted: Sat Oct 31, 2009 6:49 am
Thanks alot Fopar :
Do you happen to the parts # for the starter solenoid relay.
When I got the slant it didn't have the solenoid relay with it.
Thanks for the help.
flipfloppop
PostPosted: Sat Oct 31, 2009 7:42 am
I looked from 1978 parts catalog and it was marked Relay 8-52-328 but
I'm not sure if it is the part number because there was a note that parts indicated by name only, order by description.
PostPosted: Sat Oct 31, 2009 8:27 am
Thanks Springer: I will try that # and see what I come up with.
flipfloppop
PostPosted: Sat Oct 31, 2009 9:22 am
I think it is this:
http://www.rockauto.com/catalog/moreinfo.php?pk=943200
PostPosted: Sat Oct 31, 2009 10:41 am
Thanks Springer for the fast reply.
flipfloppop
Users browsing this forum: Ahrefs [Bot] and 1 guest
