It is currently Mon Oct 12, 2026 3:12 am
 Post subject: Chugging at speed
PostPosted: Sat Oct 31, 2009 1:16 pm
Car Model: 1986 D100 /6 A833od shortbox
If you read my prev post, I have been working on fixing a few carb related problems on my stock 86 non feedback, un-lean burned truck. So far, so good. Until it got colder. Seems like these brisk mornings are causing (exacerbating) a chugging while under load. The chugging happens at around 3000 and continues until 3500 rpms, at which point it just stops. Mind you, 2 weeks ago, no problem.
Also, when the slixer gets all nice and warm, the problem stops entirely.
Thanks for the feedback
Josh
PostPosted: Sat Oct 31, 2009 1:17 pm
What is your valve lash?
PostPosted: Sat Oct 31, 2009 1:21 pm
Ted:
I have no idea. I have owned the truck for the better part of 1 1/2 years and never looked into/read up on/adjusted the valve lash.
PostPosted: Sat Oct 31, 2009 1:24 pm
Does it have a lash adjustment if it has hydralic lifters?
PostPosted: Sat Oct 31, 2009 1:27 pm
If the motor is the stock 86 motor then thee is no valve lash. Sounds like possibly an ignition miss or a problem in the carb. Hard to say not being there to check everything out.
PostPosted: Sat Oct 31, 2009 1:49 pm
Winter blend gas? :shrug:
PostPosted: Sat Oct 31, 2009 2:42 pm
Choke not coming off properly?
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Oct 31, 2009 7:52 pm
I replaced some of the vacuum lines as they had hardened and became brittle. Motor was still warm, so no chugging yet.
Shaker
I will check the choke again to make sure. Most likely buy the electric choke with my next paycheck.
Users browsing this forum: No registered users and 32 guests
