It is currently Sat Oct 10, 2026 12:24 am
 Post subject: Balancer
PostPosted: Sun Nov 01, 2009 9:19 am
Painting my engine right now and I want to be as complete as possible (and replace old gaskets).Is there any reason I shouldn't pull the Harmonic balancer to get at the timing chain cover? Any possible complications that could arise? Also with the engine out what would be the best way to stop the crank from turning when I try and loosen the big center bolt? Engine is out.
Thanks
PostPosted: Sun Nov 01, 2009 10:50 am
Leave it in place while painting. If you remove it you will need to mask the crankshaft and seal, and also block off the annular space. You would also need to mask the balancer internal and external machined surfaces.
Just tap the center of the balancer with a hammer and wood block to slide the crankshaft as far into the block as it will go. This will prevent getting paint on the machined surface that can later slide under the outer lip of the seal.
Ken
PostPosted: Sun Nov 01, 2009 12:41 pm
6 Pack Dart
Caution Beating on the end of the crank shaft or balancer will beat on the thrust bearing (NOT A GOOD THING). To make sure balancer is on all the way use correct instalation tool.
PostPosted: Sun Nov 01, 2009 4:36 pm
HUH?
Did I not write my question right?
PostPosted: Sun Nov 01, 2009 5:08 pm
Pull the balancer,remove the timing chain cover,clean/paint etc. no problem.Only problem I could for see is finding a loose timing chain but then thats less of a problem now then when back together and in the car.Also be sure and re-install balancer per Doc's instructions ie,leave cover loose until balancer is seated then tighten cover bolts.As far as keeping motor from turning while removing/installing balancer perhaps something installed through flexplate,wedged against block etc? be creative and careful :)
PostPosted: Sun Nov 01, 2009 5:13 pm
Stop the crankshaft from turning by sticking a screwdriver through the part where the starter goes and wedge it against the flywheel so it can't turn anymore.
PostPosted: Mon Nov 02, 2009 5:56 am
If its an OLD timing chain then I would replace it .
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 31 guests
