It is currently Sat Oct 10, 2026 5:39 am
 Post subject: will thid work
PostPosted: Sun Nov 01, 2009 10:37 pm
NOS 1957 DODGE D-72 STROMBERG CARBURETOR 3-160
225 1963 valiant?
PostPosted: Sun Nov 01, 2009 11:39 pm
No, it will not work without a great deal of hacking and hassle...
...and even then it won't work well.
What are you trying to accomplish?
PostPosted: Mon Nov 02, 2009 6:46 am
you told me once and I cant find the old message about the carb linkage. Was it a 71 year that I had to look for to replace the sloppy set up I have now. Peddle to Carb linkage. The earlier post is just and alternative that Im looking into, like the stombergs, shoot I like the Zeniths better, haven't found too many of those though. did you say at one time, at mind you its been a while, that you might have some linkage stuff around. I have a couple of junk yards that have a few dodge/plymouth vehicles that Im going to scrounge this weekend. put back together the car and would like to upgrade actually from the carter B/B single to something else. to finally answer your question.
thank you for your time.
 Post subject: howz about this....one
PostPosted: Mon Nov 02, 2009 6:53 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... :MEBIDX:IT
seems to be a better suit
PostPosted: Mon Nov 02, 2009 9:08 am
I'm still not clear on what you're trying to accomplish. You want to change from a 1bbl to a 2bbl carb...? You want to change from rod-operated to cable-operated throttle...? What exactly are you trying to upgrade?
The eBay carb you linked: I've run that kind of Stromberg carb before. When they're set up correctly, they work fine. They are a very uncommon carburetor -- used only on 1963 Dodge/Plymouth big cars (B/C body) with 225 and automatic trans. No other models, no other years. Rebuild kits, floats, and parts are not available (unless you want to pay $150 for a custom-made rebuild kit...! :shock:) which tends to argue against running one of these except as an experimental kind of deal. More info see here.
PostPosted: Mon Nov 02, 2009 9:24 am
I'm still not clear on what you're trying to accomplish. You want to change from a 1bbl to a 2bbl carb...? YES
You want to change from rod-operated to cable-operated throttle...? YES
when this is done do I not have upgrade the carb anyway, or is it just taking off the linkage from the carb to the other carb.
What exactly are you trying to upgrade? I do have the 63 226 with auto trans.
PostPosted: Mon Nov 02, 2009 9:26 am
What exactly are you trying to upgrade? I messed up. I want a two barrel yes, eventually run dual two barrels, for looks and for performance
PostPosted: Mon Nov 02, 2009 9:54 am
The ebay carb you linked to is a 1bbl, not a 2bbl.
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
