It is currently Wed Jul 15, 2026 4:59 pm
Post new topic  Reply to topic  [ 296 posts ]  Go to page Previous 111 12 13 14 1520 Next
PostPosted: Thu Oct 22, 2009 2:31 pm
A 198 crank in a 225 block will give you a 198. All Slants have the same bore size. :shock:
PostPosted: Thu Oct 22, 2009 9:13 pm
What did you think I thought. I believe I spelled out the reason pretty plain
"yes the physical dimensions are the same but the blocks were thinner by 1980. I plan to get another early 60s block and use the 198 crank. "
I want a 198 stroke. if I use a 198 block like the one I had I know from sonic checking that i can only bore it to .080" oversize and have even a minimum safe wall. If I use a early 225 block like i have I can go as much as 3.56 bore which i already have done and run for two years as a 225 type engine . I dont like the long stroke of the 225. It puts piston speed in the twilight zone above what is in engine building considered safe limits. If the engine was to pushed to 7000 say.(4806 feet per minute which is 806 above what is consdered reasonably safe. ) With the shorter stroke of the 198 and providing i could bore another early 225 block the same as I already have done in my rail, I could have over 200 cubes with good rev potential from a safety standpoint. I built a 198 for my wife back in the 70s. It was a good working motor and ran mid 15s . It did not seem to suffer any lack of power despite being smaller than a 225.
SO I personally want a shorter stroke than the 4.12 of the 225 but I want a block that can be bored to use the same part no pistons I am running in my other engine. If I use an early 60s 225 block and my 198 crank with my favorite big bore pistons that will get me where I want to be safely. And I like to be where I want to be.
Don
Don
PostPosted: Tue Nov 03, 2009 7:33 pm
Any Updates?
Updates....Mmm. Projected goal next year is a 10.50. New header, maybe some head work, see if my 1972 vintage bearings need to be replaced, intercooler placement change and upgrade, higher gear ratio, new slicks, possible megasquirt, wax the paint, main studs, trans shield, port the intake....oh yea, and a thicker seat cover.
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Wed Nov 04, 2009 6:09 am
Any Updates?
Thicker seat cover for 10.50 ets? You're getting soft!!...lol
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Jan 31, 2010 9:27 pm
Very nice reading have you ran any quicker with it ?
Raymond Flynn
Registered Six Offender!!!!
PostPosted: Mon Feb 01, 2010 8:35 pm
No quicker. I have started working on it again tonight. Did some measuring for the front mount intercooler. Its a tight squeeze! Later
PostPosted: Mon Feb 01, 2010 10:12 pm
Man, the lakes are froze. Get on it!!!!!
I think studed tires are still legal in SD!!
Chris'
Autobody
Restoration
Service
PostPosted: Tue Feb 02, 2010 3:27 pm
Ice drags! HHmmmm. My slant pickup has studs on it.
PostPosted: Tue Feb 02, 2010 4:25 pm
I just sold a Hurst Verti-Gate II to a guy up in WI who ice drags a Duster.
PostPosted: Tue Feb 02, 2010 7:49 pm
Guys. I have a new idea. Why build a 200 hp slant. Let's run the ice races with what Chrysler gave us. 80 hp should be just fine!!!
Chris'
Autobody
Restoration
Service
PostPosted: Tue Feb 02, 2010 8:37 pm
I think the 80 hp would be a little out classed. Them Ice draggers are pretty serious. Go you youtube if you haven't already. Maybe we could get a Slant race on ice in MN or WI!
 Post subject: The new look!!
PostPosted: Sun Feb 21, 2010 7:38 pm
24x12 intercooler up front. 4" core w/ 3 in/out. Had to cut alittle but hope it still looks stock 8)
Later
PostPosted: Sun Feb 21, 2010 8:07 pm
It just matches the grille!
Looking good.
PostPosted: Mon Feb 22, 2010 7:28 am
Till the blue hoses go on!
Hope it works for you Ryan.
Chris'
Autobody
Restoration
Service
PostPosted: Mon Feb 22, 2010 9:45 am
:shock: Time for a skid-plate! :D
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
