It is currently Sun May 24, 2026 6:39 pm
PostPosted: Sat Nov 07, 2009 4:47 pm
I am switching from drum/drum to disc/drum. When removing my MC pushrod from the drum MC, the rubber retainer that is on the end of the push rod got ruined. Where would I find one of these, and what is the proper name? It is a 67 Barracuda.
PostPosted: Sat Nov 07, 2009 7:28 pm
Right here.
PostPosted: Sat Nov 07, 2009 9:10 pm
Cool, thanks!
PostPosted: Sun Nov 08, 2009 12:29 pm
I've heard that you can shoot some silicone into the hole prior to seating the rod and let it cure. The silicone will lock into the grooves on both the rod end and in the M/C bore.
Any problem with that?
PostPosted: Mon Nov 09, 2009 6:07 am
I have done this, on the advice of Ehrenberg. The one time I've tried it, it did not hold. It's possible I didn't get things clean enough? The brake switch keeps the pedal from coming back too far, but I need to fix this.
PostPosted: Mon Nov 09, 2009 8:44 am
I disagree with some of R. Ehrenberg's advice.
PostPosted: Mon Nov 09, 2009 12:27 pm
Usually, I think Eberg is right on with tech stuff, but there are a couple of things I don't agree with, like the 9" "fragility."
PostPosted: Mon Nov 09, 2009 12:49 pm
Car Model: 1964 Valiant V200
Yeah and the F-body spindles causing the balljoints to break, LOL.
I have successfully used a thin slice of vacuum hose.
PostPosted: Mon Nov 09, 2009 2:05 pm
I find his accuracy rate is hurt by his refusal to acknowledge his errors. I've described the brake cylinder example before.
PostPosted: Sun Nov 15, 2009 6:55 pm
I did the silicone trick w/ the 12 second drag car......went thru the traps at 100 MPH, and the rod had poped out of the plunger.DONT DO IT!!!
Andrew
Wife's: 64 Valiant
PostPosted: Sun Nov 15, 2009 6:57 pm
That sounds like excellent justification for spending the $3 on the right part! :shock:
PostPosted: Sat Dec 05, 2009 11:20 am
Andrew
NHRA rules require a positive up-stop. A simple bracket prevents this. RTV does work OK, however, as long as you "pull" the pedal/pushrod in (bungee cord) and allow it to cure for 24 hours.
Anyway, I scored a small supply of the retainers if anybody needs one.
To the guys running F/J/M-body knuckles on A-bodies: Enjoy your 3X bumpsteer!
Rick
