It is currently Wed May 06, 2026 8:10 pm
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Nov 09, 2009 5:58 am
Martin,
Thanks so much for posting this info. These heads look truly amazing. I agree this should go into the articles section.
I'll take two...
Best wishes,
PostPosted: Mon Nov 09, 2009 6:38 am
Martin, what sort of cars were raced with these engines? Do you have any information on horsepower numbers? I presume that they used gasoline for fuel.
It looks like 3.3 liters would be 3.62 X 3.25" for 201 cubic inches.
There is much more information about these special Argentinean slant six parts if you look through the voluminous postings of argentina-slantsixer.
Thank you providing the excellent pictures that I can even see on my anemic dial up connection.
PostPosted: Mon Nov 09, 2009 6:44 am
Ok I'll try to address everyone and to answer all your questions as far as my knowledge goes on this ACTC Slant Engines
It would be interesting to see one to see how much extra material is cast in around the ports. I am very sure you will run into water long before you can get ports that big with a standard head.
You are wright Zilla. This head has thicker walls all over, there is no way you can get ports this big with a standard head.
I would also be very interested in seeing cam specs and a dyno sheet to see just how much power they make at 8500. :D
They were putting out 370 HP at the flywheel as far as I know. And for the camshaft I'll have to find out, but keep in mind that the camshafts on the TC (Turismo Carretera) is one of the element without any regulation from the ACTC, so the engine builders play a lot on different cams. But i think I can find out somo known cams specs for you with some time.
Hmmmmm.....Martin.....It wasn't clear in the above posting, but are these still being manufactured? Might it be possible to purchase and import to North America? About how much...(your monetary designation or ours) are/were they? Are the above pics of a modified head, or is it "as supplied" to a racer?
This heads are no longer manufactured. Yes you can buy one and have it sent to the USA. As I said this heads are not cheap and goes from USD 1800 to crazy USD 3000, denpendind on who ported it, how it perform, if it's bare or complete. The above pics are for a full modified head, the engine builders/racers got this heads from the ACTC as a bre, partially machined casting, already with the heart-shaped combustion chamber, but without any other porting on it.
Does this head require a taller valve cover for clearance?
Although it doesn't look like, the standard valve cover fits.
Still.....very interesting what's been done. This may warrant a closer look by certain "somebodys" on this board.
Didn't get this one ...
92 millimeters = 3.62204724 inches :shock: a "906" casting, has anyone seen this casting? is it just argentina only possibly? 5 or 3 freeze plug? Maybe doc has seen one?
As far as I know is an Argentina Only special casting, developed in the late '70s by the racers and Chrysler Argentina. They put it in the 1979/80 Dodge Coronado and 1979/1983 Dodge D100 / D200 trucks to homologate it for the races, since tha engine blocks has to be a production one. It has thicker walls all over. It has 3 freeze plugs.
Here I made a mistake before, I think when SlantSixDan ask me about the "906" Block i told him the the biggest overbore you could do was 0.80 , but thas is for the regular "294" block. Sorry Dan my mistake.
But again, those crazy 91/92mm bores are only for race engine were everything has been modified for circuit race. Engines that are tear down after every race, every 15 days ...
that jeep sounds insane I LOVE IT !!!!
They sound totally wicked!!! I'm still trying to find a decent in-car video of a Dodge running on the Slant at Turismo Carretera ... hold on on me i'll find it
Give me some tiume and I'll try to find pictures of the race cars for you, so you can check! I'm very glad you like it and also about your interest in our race Slants!!!
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Mon Nov 09, 2009 7:17 am
Here are some pictures of Dodge race cars.
This is Juan Manuel Landa's Dodge and his Slant Six of 1991/92
Here Oscar Castellano circa 1985/86
And his Son Jonatan Castellano 2007
Martin Zappettini
PostPosted: Mon Nov 09, 2009 12:45 pm
Car Model: 1964 Valiant V200
Holy crap that is the most impressive piece of slant six racing hardware I've ever seen. WOW, just wow.
Do you have information on the actual manufacturer? It would be nice to see if they can be contacted to start another run of these.
PostPosted: Mon Nov 09, 2009 7:00 pm
X2... If the machinery still exists and noone in argentina is interested maybe the australians could pick up the ball. And for what its worth they would still sell if cast in iron only. This is a great lead on a performance head for our slants.
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Mon Nov 09, 2009 7:29 pm
That would be one killer shipping cost if it was done in iron. :shock:
we need alloy! :twisted:
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Mon Nov 09, 2009 7:57 pm
As far as I know this foundry went bankrupt in the late 90 ... but i'll try to find out about it. I don't think that a cast iron mold could be use for aluminum casting because of the 7% of shape reduction after casting.
If there is real interest on this heads I'll put some time doing some detective work trying to find the foundry Co. and asking them about a new batch.
Or maybe to find some used heads that might be for sale, but remember that this heads will surely be all tricked out.
Anyway the more info I'll found on this heads, or maybe even another one that might be ported different from this I'll post it here.
Martin Zappettini
PostPosted: Mon Nov 09, 2009 8:49 pm
I am VERY VERY interested,Guzzi Mark
PostPosted: Mon Nov 09, 2009 9:48 pm
That 4.0 Jeep motor sound is the sexiest thing I have heard in a long time.. I am thinking very sinful thoughts about that thing right now.
Damn girl... Where have you been all my life?
PostPosted: Tue Nov 10, 2009 3:21 am
Poser
Martin, thanks for all your work on this! I have always liked a good dective story! All the best, Wayne.
PostPosted: Tue Nov 10, 2009 4:14 pm
Car Model: '23 T-bucket
What would be real interesting is if Martin happened to run across the original molds and was able to obtain them. Even if sand-cast, there'd have to be some molds somewhere, unless they were scrapped out and are now parts of something else.
Roger
 Post subject: Clarification...
PostPosted: Tue Nov 10, 2009 6:09 pm
Martin what he means by this is, a few of our lead guys would probably be the best qualified to have one and look it over and do some research and or some "reverse" engineering with it.
Thanks for the video clips that was cool watch.
D.Idiot
PostPosted: Tue Nov 10, 2009 9:48 pm
hell I could live with a iron block, aluminium head combo :D
-Mike
 Post subject: Cool head awesome jeep
PostPosted: Tue Nov 10, 2009 10:17 pm
Sounds like straight cut gears in the jeep, which I can't afford either!
madam im adam
