It is currently Thu May 14, 2026 12:55 pm
PostPosted: Fri Nov 13, 2009 6:06 am
Hello, friends.
I have one of the rare ALUMINUM 225 Slant 6 engines in a 1961 Plymouth Belvedere. I am having an issue where the oil is building up and blowing out under pressure around the filter seal. The pump will then pump nearly ALL oil out of the engine once the rupture is established. This is an engine that hasn't been started in awhile but all of the seals and block are solid and intact. ANY IDEAS??? :?:
PostPosted: Fri Nov 13, 2009 7:30 am
Usually leaks at a spin-on oil filters are due to the old gasket sticking to the oil pump. The two gaskets don't seal to each other and there is a big leak. Take the oil filter off and make sure you only have one gasket and that it's on the filter.
PostPosted: Fri Nov 13, 2009 8:07 am
If the engine has sat for a long period, the oil pump's pressure releif valve could be stuck closed.
Pull out and service the relief valve per the FSM.
PostPosted: Fri Nov 13, 2009 8:51 am
Could also be a damaged and leaking oil pressure sender.
PostPosted: Fri Nov 13, 2009 7:29 pm
I agree with both Doc and Dan, I had a sending unit really leak bad because of a pressure release valve plunger, beeing stuck,Guzzi Mark
Users browsing this forum: Google [Bot] and 40 guests
