It is currently Wed May 27, 2026 8:23 pm
 Post subject: engine date I.D. where?
PostPosted: Fri Nov 13, 2009 9:21 am
hello, can someone tell me where the date of engine stamping is located on the block on the /6 please ? Thank you, Brian.
PostPosted: Fri Nov 13, 2009 10:01 am
head deck under #1 plug behind alt
PostPosted: Fri Nov 13, 2009 12:27 pm
are you saying on the cyl. head itself? I need to know the date of the block, I have replaced the head with a different onein the past.
PostPosted: Fri Nov 13, 2009 12:34 pm
No, it's on the block itself, on the top surface of the block deck, usually directly below the frontmost spark plug. If you have a late-production block it may be below the rearmost spark plug. If you have a 1960 block, it may be on the rear or top of the water pump scroll area.
PostPosted: Fri Nov 13, 2009 2:23 pm
It should be on this boss:
