It is currently Sun May 31, 2026 7:00 pm
 Post subject: wheel hole pattern chart
PostPosted: Fri Nov 13, 2009 6:15 pm
I thought that I saw a posting with a chart in this forum that showed one how to measure the hole pattern size on wheels with 4, 5, 6 bolt holes,
on some sizes you measure across holes from the hole center, others are measured from the inner edge,, anyone know where that is,,
I usually have some luck with the search function, not this time.
thanks
PostPosted: Fri Nov 13, 2009 9:21 pm
I bought a cheap, plastic template at a swap meet . Makes checking bolt patterns quick and easy, Looks kinda like this one:
https://www.made4uproducts.com/cart/pro ... d=80-21392
obliquely-inclined state of mind
PostPosted: Fri Nov 13, 2009 9:24 pm
On five-bolt patterns hook your tape measure on the outside of one stud and measure to the center of the one diagonally opposite.
