It is currently Fri Apr 24, 2026 9:40 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Nov 12, 2009 7:25 am
Radarsonwheels: Sounds like straight cut gears in the jeep, which I can't afford either!
yes, and you also can hear in the video how the gear box literally BLOWS!!! :shock:
I have found out that the company that casted this heads is in Tandil city, I tried to call but didn't get any answer. I'll be at that city on january for holidays, So I will spend some time there to see what happens ... :P
Still can't find a a in car video of a Slant powered ACTC Dodge car ... damm :(
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Sun Nov 15, 2009 4:34 pm
weren't the old muncie manual trannys straight cut gears ? What makes straight cut gears so great ? ( I must be showing my youg age here)
-Mike
PostPosted: Sun Nov 15, 2009 5:30 pm
Muncie transmissions have helical cut gears. They were just a better trans than the Saginaw units. Straight cut gears are quite loud.
http://en.wikipedia.org/wiki/Gear
PostPosted: Tue Nov 17, 2009 6:05 pm
Thanks joshie didn't know, but is there any advantage to having straight cut gears over helical cut gears ?
-Mike
PostPosted: Wed Nov 18, 2009 7:10 am
Hey Mike, straight cut gears are stronger, but promote the old "if you can't find 'em - grind 'em" syndrome and other situations like double clutching to shift. I think the 4wd crowd likes them for pulling out tree stumps and boulders.
On the cylinder head, I am looking forward to seeing more about this ACTC casting, where they can be obtained or if casting molds are sitting in a warehouse somewhere!
PostPosted: Wed Nov 18, 2009 7:23 am
Straight cut are also much easier to shift without using the clutch - good for road racing and other venues.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
