It is currently Thu May 28, 2026 4:01 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Thu Oct 15, 2009 6:47 pm
sand blast a new intake and leave it outside for a bit. that'll get ya some nice surface rust
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Fri Oct 16, 2009 6:07 am
Hum Aluminum rusting, Must be the cheap China kind!!!! :lol: :lol: :lol: :oops:
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Oct 16, 2009 10:26 am
You could run a crusty iron 2bbl untill you figure it out.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri Oct 16, 2009 12:52 pm
Car Model: 1964 Valiant V200
Think I found an SU manifold. Now to find three HS6 SUs.
PostPosted: Fri Nov 20, 2009 2:33 pm
So there you have it. I think I'll use three Datsun Hitachi SUs because they flow 210CFM each and are fairly inexpensive. Should be pretty good for a hot street slant.
PostPosted: Fri Nov 20, 2009 2:41 pm
I think you mean:
That's pretty cool! Never heard of that manifold before. Where did you find it?
PostPosted: Fri Nov 20, 2009 3:35 pm
Do you use a lawnmower carb for the little hole on top?
:D
PostPosted: Fri Nov 20, 2009 4:00 pm
Secret stash :)
It's australian actually. Probably not the best design for ultimate performance but should work fine on my stock-rod motor.
PostPosted: Fri Nov 20, 2009 4:05 pm
Pretty cool. Although, actually, technically, ALL intakes suck (or at least channel the motor's suckiness). :wink: That top hole is for the PCV valve fitting.
PostPosted: Sat Nov 21, 2009 7:05 am
Can you fit a triple carb setup on a left hand drive slant? I thought the brake cylinder would be in the way?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sat Nov 21, 2009 8:44 am
Maybe with power brakes but seems like plenty of space in my car. It doesn't stick out that far actually.
 Post subject: Yep...
PostPosted: Sat Nov 21, 2009 11:31 am
That would be correct, the shorty rams with small carbs should fit nicely with manual brakes....
Looks like a fun choice to me.
PostPosted: Mon Nov 23, 2009 5:53 am
Good to know, please post a picture when installed on the slant. Thanks
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
