It is currently Thu Jun 04, 2026 9:22 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Wed Oct 14, 2009 10:15 am
More info from a link in that HAMB thread that may be of interest.
-James
Particularly to those like me who think that P.T. Barnum underestimated a certain demographic's birthrate.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Oct 14, 2009 9:37 pm
Don't you know that the fish carb works according to the principles of Turbo-Encabulation? The girdle spring is one of the giveaways, as is the sinusoial depleneration.
PostPosted: Sun Nov 22, 2009 9:22 am
:shock: dug this thread up for mpgslant6. funny stuff.
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
 Post subject: fish carbs
PostPosted: Sun Nov 22, 2009 5:13 pm
Fish carbs were never marketed by the manufacturer as "100mpg"carbs. I don't know where they got that label, I just wish people would look into there history. They were a real carb and had enough performance to win races! Most of you are aware of another carb using the same basic design, if I were to ridicule that carb I'd probably be blasted from this forum. I expected a little more intalectual honesty here.
Dave
1972 d-100 parts truck
PostPosted: Sun Nov 22, 2009 5:52 pm
http://www.fireballroberts.com/Fish_Story.htm
Dave
PostPosted: Sun Nov 22, 2009 6:27 pm
It would be fun to try one if it was designed like drawing and if it would fit on the SL6.
PostPosted: Mon Nov 23, 2009 5:47 am
Ted, they made adaptors to fit the slant six carb base, you would have to make up the linkage though. I have a friend with a bunch ( 4 or 5) of them he bought on e bay, he tried a dual setup on a modified flathead Ford. I don't know what he did but I heard he did not like them and now has a set up with modern Strombergs on it. From what I have read it seem tricky to tune if you don't follow the directions, but what do I know.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Mon Nov 23, 2009 5:00 pm
When I was running one, I made my own adapter. I even put a manifold vacuum port in it, Its nit that hard if you can drill tap and grind metal.
Dave
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 13 guests
