It is currently Mon Jun 22, 2026 7:28 pm
 Post subject: seized engine
PostPosted: Mon Jun 02, 2003 2:48 pm
I wanted to relay my latest experience with rebuilding my 62 Dart. The car had sat up for twelve years in a barn. After learning there was no compression in the # 4 clyinder I had the engine rebuilt. I proudly installed the rebuilt engine. I received good advise on this list on how to get the new engine running. With the car running I drove the car showing most of my friends. The next morning I attempted to crank the car. Nothing. The engine was sounding bad. After considerable trouble shooting, I found the push rods bent and valves sticking. A mechanic told me my failure to get out the gas from the tank prior to restart had caused the valves to sieze. Fun stuff, huh.
PostPosted: Mon Jun 02, 2003 3:43 pm
Yuck....I hate it when that happens!
I have to say that I have "been there, done that."
Live and learn, now when I go to start a car that has been sitting a long time, I simply dis-connect the rubber hose going into the fuel pump and stick-on a longer hose leading into a freash can of gas. I start and run the car on that 'side can' until I have time to drop and clean out the fuel tank.
 Post subject: What's the connection?
PostPosted: Mon Jun 02, 2003 7:26 pm
I understand the engine stumbling around on old gas but what's the reason why valves stick/push rods get bent?
Cheers!
Al T
PostPosted: Mon Jun 02, 2003 7:55 pm
Old gas turns to varnish that gets very stickey :shock:
not good for a motor, of course this must have been REALLY old gas :shock: :shock: :shock:
