It is currently Tue Jun 23, 2026 10:35 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 22, 2009 6:37 pm
Car Model: 1964 Dodge Dart GT - 2 door hardtop - 225 Slant 6
I "super sixed" my 1964 Dodge Dart GT with a 225 slant by grabbing a super six intake on eBay and attaching a Weber 32/36 progressive two barrel carb. The machine has never run better! If you can do this setup I highly recommend it.
The only "issue" is adapting the carb to the intake, but this is easily solved by using a two piece adapter you can find on almost any Chrysler Jeep enthusiast website (the Chrysler Jeeps used an inline six with a 2-barrel carb that had the same bolt pattern as the super six Holley carb has; and it is very common for those jeep owners to slap Weber 2-barrels onto their vehicles, so getting the adapter is easy).
The only other thing I did was change out the exhaust manifold to the 3 inch exhaust that the super six uses instead of sticking with the stock 2.5 inch outpipe.
I just bolted my setup on and started the car.
Good luck with whatever you decide to do though.
EDIT: I was also able to setup the carb to use the stock throttle linkage that your Carter BBS uses, if you would like pics or more info on my engine/carb setup let me know and I can e-mail you photos, just send me a PM on the forums.
1964 Dart GT
225 "Super Six" w/ Weber 38 DGES
GM HEI, Nippon Denso 80A Alternator and high torque mini starter
