It is currently Sun Jun 07, 2026 7:33 am
 Post subject: 1970 Slant Six questions
PostPosted: Tue Nov 24, 2009 10:41 am
I just acquired a new (old) Slant Six and would like to start working on it over Thanksgiving. What size bolts do I need to mount it to the engine stand? Also, is there a way to tell if it's a 198 or 225 before I pull the head? It's out of a 1970 pickup. How much can the block be safely bored? If it's a 198, can I make it a 225 just by swapping crank rods and pistons?
Ken
PostPosted: Tue Nov 24, 2009 3:34 pm
Ken
Welcome to the forum. You can make a 198 a 225 just with crank and rods. The pistons are the same between ALL the slants. To id Look under number 1 plug on the smooth area of the block. On the home page of this forum is a series of articles on how to do all sorts of things to a slant. Read them and use the search function. Then if you get stuck ask questions in the correct section.
Which stand do you have? lenghts will vary.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Nov 24, 2009 3:47 pm
Hi Frank,
Thanks for the reply. I just need to know thread size, then I'll buy bolts long enough for my stand with about 1/2 to 3/4 thread into the block. As for my Slant, I'm probably going to go the "long rod" route with KB268 pistons. My intake choices are a factory 2bbl or an Offy modified for dual webers. Can hardly wait to get started on it.
Cheers,
Ken
