It is currently Wed Jul 15, 2026 10:25 pm
PostPosted: Tue Nov 24, 2009 8:23 pm
I'm going to use a Vertex Magneto in my dragster, and it has the nylon gear. The cam will be a billet cam , and I would like to find out if anyone has any idea where to get a aluma-bronze drive gear like the ones used on all steel billet cams ?
I have a guy who will cut me one for $200.00 ..... I would like to have a few .
Mike Alkydigger@yahoo.com
Mike Chilando
WWW.Alkydigger.com
615-483-6830
nashville TN
PostPosted: Tue Nov 24, 2009 8:31 pm
I seem to remember that the Cox Brothers had some made for use with their roller cams. Maybe someone knows where one of them are. I had a Vertex once and it had a bronze gear on it (this would have been in the late 60s). I sold it to a guy for $75! I would be interested in learning more about your car. I will do a search and see what you have posted.
PostPosted: Tue Nov 24, 2009 8:35 pm
There's a bronze slant-6 distributor drive pinion made in Australia and available from Pentastar Parts.
PostPosted: Wed Nov 25, 2009 3:48 am
I looked at the listing and it says "NOTE : ONLY SUITABLE FOR AUSTRALIAN PRODUCTION 'BOSCH' POINTS DISTRIBUTORS." Then that is followed by a footnote that indicates it suits all slant 6 distributors. I would want that bit of ambiguity cleared up before I bought one.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Nov 25, 2009 6:14 am
Please share with us the answer you get when you write in and ask 'em.
 Post subject: Cox Brothers ?
PostPosted: Wed Nov 25, 2009 7:11 am
Who are Cox Brothers ? How Can I contact them if they are still in business ?
Mike
Mike Chilando
WWW.Alkydigger.com
615-483-6830
nashville TN
PostPosted: Wed Nov 25, 2009 8:42 am
I am pretty sure that the gears the Cox boys have (had) were for the oil pump drive and not the distributor.
I have not talked to either John or Jim Cox in a couple of years so I am not sure if they still have any.
I still have some of the bronze oil pump drive gears.
PostPosted: Wed Nov 25, 2009 12:28 pm
Well, since I'm not the one buying a bronze gear, that letter is likely to be delayed for some time. In other words, don't hold your breath.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Nov 26, 2009 8:33 pm
As long as it fits better than the Dorman Help gear 90450... :roll:
Surely someone has purchased that Aussie gear and will come along and update this thread! :)
74 Dodge Charger 225 factory A/C auto 1920 carb stock exhaust.
Mods;
HEI, MSD B3, Magnecor 8 mm, ZFR5N, .060 rotor, CH410X cap, new 3874814 dist, fuel mod, valves hot .010 & .020, all new hoses, JP chain, brake hoses and fluid.
PostPosted: Thu Nov 26, 2009 8:49 pm
What fit problem did you have with the nylon gear? Let me guess: The hole's drilled in the wrong place and when you install it there's a big gap between the top of the gear and the bottom of the distributor?
 Post subject: Yep...
PostPosted: Thu Nov 26, 2009 9:17 pm
That's always the problem with the Dorman/Help! gear.
PostPosted: Thu Nov 26, 2009 10:38 pm
That's not a problem, and it's not confined to the Dorman gear. They're all drilled in the "wrong" place -- even the genuine Mopar gears -- and always have been, because that's not the roll pin hole. Never has been.
See this post (and the rest of the thread).
This, like the spark plug ring washer thing, is one of those little bits of slant-6 service knowledge that keeps trying to get buried in the sands of time.
PostPosted: Fri Nov 27, 2009 8:01 am
I measured the shaft of the Vertex and a stock distributor: Both are .500" So assuming the Auzzie gear will fit a .500" shaft, then it will in fact fit a stock distributor and a Vertex.
Mike
Mike Chilando
WWW.Alkydigger.com
615-483-6830
nashville TN
 Post subject: Here's the answer...
PostPosted: Sun Nov 29, 2009 10:28 pm
From a reply to an email I sent the other day:
Thanks for your email. I have revised our listing to read 'Bosch Australian Distributors Only' to clear up any misinformation that may arise. However I can tell you that I have on a few occasions sold the gears to US Slant 6 owners, The primary difference between this (bosch) gear and the Mopar gear is the bore size of the shaft. The bosch gear needs to be bored to suit the Mopar shaft, as far as I am aware they are interchangeable once this modification is complete.
kind regards,
Ray Webb (Jr)
Just thought you lads (and lasses) might want to know... I sent another email inquiring about the actual diameter and will post what I find out.
Josh
 Post subject: As promised...
PostPosted: Mon Nov 30, 2009 7:55 pm
The gear ID is 12.44mm
or about 0.490" so a slight lapping of the ID and the gear should fit.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 11 guests
