It is currently Sat Nov 21, 2026 1:29 am
 Post subject: Got a Slant
PostPosted: Tue Jun 03, 2003 10:34 am
Through a buddy on RamChargercentral.com, via a person on Pirate4x4.com, I recieved a complete, carb-to-pan-to-bellhousing Salnt 6. It supposedly has 30,000 miles on it, was in a truck, and was pulled in favor of a V8.
It looks pretty good on the outside :roll: , comes complete with a Super Six setup and clutch, and turns over readily.
I was trying to ID this engine. I think I have it narrowed to a 77-80 version using the handy SS.org slant ID guide (http://www.slantsix.org/articles/parts-matrix/jpg.htm). Only question is: cast or forged crank. The block ID numbers go 030-12, 0457, with the suffix AAWJ.
It has no spark plug tubes. I'd prefer a solid lifter, forged crank, but we'll see when we open it up.
Any feedback on whether this is a worthy start on a race engine?
PostPosted: Tue Jun 03, 2003 12:51 pm
Check the machined pad right below the #1 spark plug. If there is an E after the 225 then it has a cast crank.
PostPosted: Fri Jun 06, 2003 12:33 am
Upon closer examination, I have a 77-78 AAWJ block, solid lifters, cast crank. The head is casting # 3698447 which is the revised combustion chamber design with the small spark plugs.
So, is this a suitable core for a race engine, or should I look for a forged crank?
Should I put the head on an older, forged block, or should (can?) I install a forged crank/rods in this block?
Or is the cast crank fine for HD use?
PostPosted: Fri Jun 06, 2003 11:31 pm
If you are going to build a Slant, I would find a forged crank engine.
In your case, where you have a nice low miles cast crank engine, use it.
Mike Jeffrey ran the first 10 second 1/4 mile pass for a SL6 "doorslammer" with a cast crank engine.
As for awapping-a forged crank into a cast crank engine, that does not work, the bearing sizes are different (smaller width) in a cast crank engine.
