It is currently Sun Jun 14, 2026 8:44 am
 Post subject: Band Sawed Slant 6 Head
PostPosted: Mon Nov 23, 2009 3:59 pm
Mods...maybe a sticky?
I don't have the head any longer so these are the only pics I have. I sent it to member Lucky13. I think he may have passed as he was having health issues. He hasn't been on since last June. I even sent a letter to his home with no response. :(
Intake on the left. Notice the deck thickness.
Intake on the right
Intake on the right. Your machinest needs to be careful with hardened exhaust seats as there is not much material there.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Nov 23, 2009 5:32 pm
This is great stuff for anyone planning a port job. Thanks!
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Mon Nov 23, 2009 7:09 pm
Cool stuff Shaker! Thanks!
PostPosted: Tue Nov 24, 2009 10:38 am
ah very nice !!
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Tue Nov 24, 2009 3:16 pm
Do you remember what gereration head this was? Was the head stock or all ready messaged?
Thanks for some great pictures.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Nov 25, 2009 5:23 am
It was a stock head that was untouched. It was a drool tube head but don't recall the casting #.
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Nov 25, 2009 5:27 am
Thanks for posting this. It had me dreaming about porting the head on the Dart... literally.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Dec 02, 2009 9:24 pm
Thanks that give me the "courage" I needed to grab the die grinder and start a light port job. Great pictures
Thanks Mike
PostPosted: Tue Dec 08, 2009 5:29 am
shaker, i know the head is gone but, any guess or measurment to how thick is the deck ? looks like 3/8" or more to me. thanks, ronnie
PostPosted: Tue Dec 08, 2009 9:39 am
It's probably closer to 1/2". Look at the diameter of the quarter vs the deck.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Apr 07, 2013 4:42 am
I know I know, I keep reviving old threads but here goes...
Currently on a ipad so I can't do the work I want but the photos will still yield measurements w a little work. The standard qtr is .955 inches. Or 1" without getting to technical, so then if some one laid out grid work or even used a guide on the photo by measuring the qtr first, one could use it to ID how thick the deck is etc.
Now here's why I posted, in the top photo there is a pocket under both qtrs and one has a hole the other doesn't. What are the pockets? Coolant pockets? I'm brainstorming again and found these photos and the pockets are in the way! Lol. So educate the young in if anyone knows pls.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
 Post subject: Yep.
PostPosted: Sun Apr 07, 2013 7:34 am
Yes that's a coolant passage, the one that doesn't have them is the end of the head (see the rocker shaft stand at the top of the "chunk").
PostPosted: Sun Apr 07, 2013 8:29 am
Well there goes that idea :evil: , roaming the web and thinking I had thought of cold start injectors and long story short I was trying to incorporate as close to direct injection as we could get.
Sometching like that was the thought but never mind. If the injector stuck in far enough and fire downward. An injecto like this
So that was the thought but with coolant in the way that would really mess things up. So onward with more wild thoughts... :roll:
Users browsing this forum: Ahrefs [Bot] and 1 guest
