It is currently Fri Nov 20, 2026 7:18 pm
 Post subject: spark plug gap
PostPosted: Wed Jun 04, 2003 11:16 pm
Ok, I know this has been talked about before, but my searching didn't come up with anything, so here it goes again. What is the best gap for a stock 225 slant. My manual says .035, but it seems like I've heard that some of you run .040, is that right? Is there a performance difference, or should I just get the stock ones (in Autolites, of course)? Thanks
PostPosted: Thu Jun 05, 2003 4:52 am
You can set the gaps to quite a wide range and it won't make much difference. 0.035"-0.040" will work just fine, so just use the stock spec.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 10 guests
