It is currently Wed Jun 17, 2026 11:19 pm
 Post subject: Radiator options
PostPosted: Sat Dec 05, 2009 1:34 am
hi Guys
The radiators in this part of the world, that are still serviceable is getting few and far between - so we are more and more looking at aftermarket ones
Flex-a-lite and so on is readily available over here at a lot less than having the copper rad re-cored - labor is very expensive over here
So suggestions please - this is for my 68 FB \6 barracuda 74 Valiant Charger \6 aka 71 dodge demon
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sat Dec 05, 2009 7:42 am
See here. Whether it does you any good in RSA depends on whether you're willing to pay shipping!
PostPosted: Sat Dec 05, 2009 8:25 am
I got an inexpensive universal aluminum radiator from Speedway. Its for a chevy engine so the bottom outlet is on passenger side, top is driver side ( its a cross flow). Had a friend weld on flat tabs on both sides for the mounts. Drilled holes using the old radiator as a template. It sits a bit lower than the stock downflow. The bottom uses a stock hose but the top used a hose pulled from the parts store rack and cut to fit. Also need to change the neck to a straight one from a V8. Works great.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sat Dec 05, 2009 12:25 pm
Hi Dan - nice rad just blooming expensive - but VERY nice
But for the price plus shipping I can buy a flex-a-lite for each of the cars ..sob :cry: Such is life
Regards,
Fanie Gerber
PostPosted: Sat Dec 05, 2009 12:59 pm
The universal radiator plus hoses and friends help with welding was less that $200. Finished it looks as nice as Dans, except it flows the other way so it dose not look stock.
Users browsing this forum: Amazon [Bot] and 5 guests
