It is currently Fri Jun 05, 2026 7:13 pm
PostPosted: Tue Jul 15, 2008 7:24 pm
Is it possible to pull a SB oil pan on my 77 D200 (2WD) without Lifting the engine / Loosing the Motor Mounts?
It is Developing a nasty Driveway spot That will need taken care of.
Thanks,
PostPosted: Wed Jul 16, 2008 1:23 am
If I remember correctly-yes. I had mine off of my 82 D150 ( 360 ci ) a couple of times for various reasons.
Good Luck
Todd
1968 Valiant V200-a Work in Progress
PostPosted: Wed Jul 16, 2008 3:54 am
Thanks Todd.
PostPosted: Wed Jul 16, 2008 11:20 am
Yup. Been there, done that. Last one was actually my old 87 B van; I replaced that pan on my lunch hour! (it was handy being able to have the use of a drive on 4 post hoist, when I worked there!) That one did the old Ford trick, of rusting out just below the mounting flange. There was more similarities on the front end of a B van as compared to a D series pickup than many would realize! Susp. was the same, just different steering linkage.
 Post subject: oil pan
PostPosted: Sun Dec 06, 2009 6:39 pm
I've done it in a 77 d-200 small block
Dave
1972 d-100 parts truck
PostPosted: Sun Dec 06, 2009 8:38 pm
yup had the pan off my 318 in my current DD 83 D 250 after dropping a pushrod down into the pan. Didnt have to jack up the engine or unbolt anything beyond the starter the trans insp. plate (727), and the pan itself.
PostPosted: Sun Dec 06, 2009 8:55 pm
I replaced the oil pump on a 360 in a 79 B250 van without even dropping the drag link. It did have dual exhaust though.
