It is currently Thu Jun 11, 2026 4:21 am
 Post subject: engine swap
PostPosted: Mon Dec 07, 2009 7:24 pm
I have a 63 valiant with a 170. By cast #"s it is a 1965 engine with a 4 speed trans.
I also have a 1970 225 out of a 1 1/2 ton truck, it was a 4 speed also.
I want to pull the 170 and replace it with the 225, By cast #'s the 225 is listed 68-70
Any issues i need to be fore warned about.
Thanks Nick
PostPosted: Mon Dec 07, 2009 8:04 pm
You'll need to swap the oil pan and pickup. You'll also need a '68+ car flywheel as the newer 225 has a larger flywheel centering ring on the crankshaft than the 170. Also, the exhaust pipe will be a little short and won't reach the exhaust manifold in it's new, higher location.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
