It is currently Fri Jun 19, 2026 6:01 am
PostPosted: Wed Dec 09, 2009 4:58 am
Hi guys, what´s the correct thermal grade of spark plugs on a standard slant 225?
Aspen 79 Holley 1920 HEI
Aspen 80 Super Six
PostPosted: Wed Dec 09, 2009 8:24 am
Up here in North America, the 1975 and later slant-6s use a (physically) different spark plug from the 1974 and earlier engines. I'm not sure if that same change was made in South America. Can you show us a picture of one of your present spark plugs? Or tell us its number?
PostPosted: Wed Dec 09, 2009 8:42 am
Ahhh, yes my slant use a conic seat and de thermal grade is # 16
Aspen 80 Super Six
PostPosted: Wed Dec 09, 2009 11:15 am
OK, so that is the same newer type of spark plug that was used in North America. I am guessing your #16 is maybe a Champion number, in which case that seems too hot. Can you get NGK spark plugs? If so, try a #UR5.
PostPosted: Fri Dec 11, 2009 10:08 am
Dan correct number is T16PR-U11 and is make is denso, Thanks
Aspen 80 Super Six
Users browsing this forum: Ahrefs [Bot], curmudgeon and 3 guests
