It is currently Sat Nov 14, 2026 12:58 am
PostPosted: Wed Dec 09, 2009 1:10 pm
OK not my slant but the 318 and since they use the same starter and electrics.......
Turn key - no starter
short out bat and relay feed on starter no go......
Take the one from the Chargers stripped parts bin - It worked before...
short out bat and relay feed on starter - starter runs...
OK test Starter relay output - zilch
Replace
Turn key.. no starter |^%$!!!!!!!!
Test THIS relay... (*&^%$#@!!!!!! dead
Bought new ones plus 2 spare now all is well
And the original starter... well it is in for a rebuild
31 years is not bad for such a relay
The fact that both failed at once is bad that I did not cotton on to this early on and do my normal test is even worse
That they both kept working ........
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Dec 09, 2009 6:29 pm
sometimes they give you love and some times they demand it....
I dont care what any one says...%$%$#$# usually works sooner or later :wink:
Its so nice out side, I think I'll go lay under my car..
