It is currently Wed Jun 17, 2026 11:07 pm
PostPosted: Tue Dec 08, 2009 7:19 pm
I'm getting ready to swap my auto for a 4-speed, just wanted to know what to expect. My engine is a '64 225. Thanks
SOLD! Went to New Zealand. '64 Valiant Signet 200, 2-dr hardtop. 225/4-speed/Pistol Grip, Offy 2-1bbl, Clifford headers.
Minimum government means maximum LIBERTY!
PostPosted: Tue Dec 08, 2009 7:29 pm
Seems like Doc posted recently that early cranks (60-61) might not be drilled and for a few years following that, if they were drilled; might not be bored to the correct (finished) size for a man. trans pilot bushing.
Try searching his posts, I'm thinking this was within the last week or so.
And definitely don't take my vague recollection for the gospel...
Just trying to get you started in the right direction, if I can.
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Wed Dec 09, 2009 1:34 pm
By 1964, all of the SL6 cranks were being drilled for the pilot bushing but as already noted, some are not finish reamed to size.
You will have to get to the back of the crank and take a measurement before you will know which pilot bushing you will need... or buy one of each type... just in case.
PostPosted: Sun Dec 13, 2009 6:10 am
And by the time you get to the late '70s with the cast cranks they stopped drillling all the cranks. The one in my engine was not drilled.
PostPosted: Mon Dec 14, 2009 3:23 am
My 65 matched Doc's description.
I used the special bushing that NAPA sold (at least last year) that has a reduced OD to fit the drilled but not reamed hole.
