It is currently Tue May 26, 2026 12:25 am
PostPosted: Tue Dec 15, 2009 2:01 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Got a coil from Ebay in the mail today. Said it was made in the USA, looks fine, so...
But the wire connections aren't marked positive or negative. Which is which? Don't want to blow anything...
Also, anybody have a part # for the wire harness that will plug directly to the coil?
Thanks again,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Dec 15, 2009 2:37 pm
More info, plz. There are various different HEI coils.
PostPosted: Tue Dec 15, 2009 3:10 pm
PostPosted: Tue Dec 15, 2009 3:14 pm
6 Pack Dart
Does it have two side by side in two rows (Flat terminals) or what?
PostPosted: Tue Dec 15, 2009 3:21 pm
Looks like it could really use a plug connector--and there are two side by side in two rows, as Fopar says.
The only thing it says on the coil is Made in the USA. Looks to be the equivalent of the IC22?
I'll try to get a photo up.
JOe
Joe Hoppe
PostPosted: Tue Dec 15, 2009 3:24 pm
Coil is billed as "replacement to JEG's Red-Hot Igntion Coil GM HEI 84-95"
if that helps,
Joe
Joe Hoppe
PostPosted: Tue Dec 15, 2009 4:25 pm
6 Pack Dart
OK go to search and enter
HEI Ignition Comparision
Donpal has a couple of pictures you can see how its done, and the connecters can be bought new ask for coil pig tails
PostPosted: Thu Dec 17, 2009 2:10 pm
Send me a PM with your email & I'll send full size pictures identifying positive & negative terminals among other things.
You can modify the picture of the wiring diagram to match you installation by opening the diagram in paint & making changes to match your final installation including part numbers.
Print the wiring diagram & carry it in the car so that 5 years from now, if you need to take some HEI action, you'll have a reference of the mods recorded & handy....especially on the road.
PostPosted: Thu Dec 17, 2009 3:36 pm
PM Sent. Thanks, DonPal.
Joe
Joe Hoppe
PostPosted: Sat Dec 19, 2009 10:34 am
Got it running nicely Saturday morning. Thanks for everyone's help.
Joe
Joe Hoppe
