It is currently Wed Jun 03, 2026 6:49 pm
 Post subject: Aluminmum block
PostPosted: Mon Dec 14, 2009 8:40 pm
A friend of mine is pulling a /6 out of a 60 dart it's an aluminum block is it worth rebuilding???? I'm thinking that I may try to build a sleeper
PostPosted: Mon Dec 14, 2009 8:46 pm
The aluminum block takes special knowledge, care, and parts (head gasket, rear main seal set, main caps...) to assemble correctly. These parts are not generally available any more, but they can be found with effort and persistence. The aluminum engine is much more subject to corrosion damage than the iron engine, and is not well suited to high compression or other high-zoot buildups. They can be made to run well in stock or roughly-stockish form.
PostPosted: Thu Dec 17, 2009 10:30 am
i had one that i sold for 900 bucks! i wish i wouldn't now but they are beautiful! a real peice of art...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Fri Dec 18, 2009 8:12 am
I am putting together a "healthy" aluminum engine. I have all the pieces, but they are currently up in WI/MN and I'm in VA. I plan to make about 220 HP. We'll see how this works out. For anything wild, go iron block.
If we could get a real MLS head gasket made by Cometic or someone else, this would likely alleviate problems with cylinder sealing issues and of course gasket availability.
Best,
PostPosted: Fri Dec 18, 2009 9:39 am
I
Best,
I spoke to Cometic, also, at the PRI show, and the impression I got was, it is not likely. The best thing to do, is anyone that would like a gasket, contact them. If they feel there is a market, it might happen.
PostPosted: Fri Dec 18, 2009 11:04 am
Thanks, Charlie. I will do that when I have a spare moment ( :? ). My guess is we could sell 30-50 of these pretty quickly.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
