It is currently Tue Jun 23, 2026 7:04 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 27, 2009 8:40 am
the bat. voltage is 11.7 the voltage at the restistor is 11.7 the voltage after the resistor is 7 the voltage at coil is 7 i rplaced the coil put point and condenser back in i think you are right kevin i will charge the battery and see if that helps the sitiuation..................im just not shure why it was running and stalled out and died then nothing after that
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Dec 29, 2009 4:14 pm
i charged the battery hit the ignition had the classic nananoway nananoway and it started success thank you guys for all your advice
85 d-100 HEI 2BBl
06 Toyota Corrola
