It is currently Fri Jun 19, 2026 5:11 pm
 Post subject: starter question
PostPosted: Tue Dec 29, 2009 4:26 pm
i have a starter question are there any late model engines with the fast spinning starters that will bolt on a 85 slant six? maybe the 318 or 360 magnum i have seen the aftermarket ones but they are a little out of my price range thanks in advance
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Dec 29, 2009 4:55 pm
Yes.
http://slantsix.org/forum/viewtopic.php?p=110054
PostPosted: Tue Dec 29, 2009 6:16 pm
thanks josh
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Dec 29, 2009 6:25 pm
I forgot to mention that I go to car-part.com or a U-Pull-It type wrecking yard to buy the Nippondenso starters. There is also information on replacing the solenoid contacts (most common failure) is on the board too.
PostPosted: Tue Dec 29, 2009 6:27 pm
Site Admin
Check out the links in the FAQ at the top of this section too! :D
CJ
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
