It is currently Sat Nov 21, 2026 8:22 pm
 Post subject: turbo
PostPosted: Wed Jun 11, 2003 5:50 pm
Is there any info that someone can give me on turboing my slant. i will need all that will need to be done.my buddy has one that he will give me just do not have a clue how to thanks for any help :?
PostPosted: Wed Jun 11, 2003 11:03 pm
A good place to start is a book by Corky Bell called "Maximum Boost."
www.wagnermotorsports.com is another good place to go for info. You should give Andrew Wagner a call there if you are serious. He can give good advice and fabricate parts for you.
 Post subject: Turbos
PostPosted: Thu Jun 12, 2003 5:53 pm
<i>Maximum Boost</i> is a good book, but I sometimes think Corky Bell mixes facts and opinions a bit freely and doesn't always say which is which. It's still a great book for building a turbo car, particularly a EFI one. However, Hugh MacInnes's <i>Turbochargers</i> has a lot more to say about carbs and turbos. However, I'd recommend both - it's hard to research something too well before starting!
BTW, what turbo is it your buddy has? Not all of them work well on slants...
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: turbo
PostPosted: Thu Jun 12, 2003 6:47 pm
it came off buick gn t 100 i think :? is that a good one the car ran 11.20et
 Post subject: GN turbo
PostPosted: Fri Jun 13, 2003 7:26 pm
Yeah, that's perfect. The Buick V6 is almost exactly the same size as a slant six. It's just that there are used turbos floating around off everything from Chevy Sprints to big rigs, and I've seen some incredibly creative mismatching. My favorite was a Buick V6 turbo on a lawnmower engine - it wouldn't spool unless they fed it with compressed air through the exhaust, and then it would hit the surge limit....
PostPosted: Sat Jun 14, 2003 9:22 am
This is interesting :D I got more questions... Do you get enough RPM on a stock motor to get full use of a turbo? Thinking maybe it's best to at least change cam to match the RPM's...
www.moldestuket.com rad-rides fom molde in Norway
 Post subject: Answer to your question
PostPosted: Sat Jun 14, 2003 11:02 am
Rad to answer your question about stock and turbos, do a search on Tom Drake. Happy reading!
Cheers!
Al T
 Post subject: Depends on what turbo
PostPosted: Sun Jun 15, 2003 6:04 pm
Different turbos work best at different RPM's. For example, a stock slant six spinning at around 3,000 RPM with a TE04 off a K-car turbo at around 8 psi of boost would be right smack dab in the peak efficiency of the turbo. A Buick turbo might be happier another 1,000 RPM or so higher, although I can't verify that without a compressor map. But the Buick Turbo V6 is no rev-monster either. So I'd expect it to be a reasonable match for a slant six.
