It is currently Fri May 15, 2026 4:35 pm
PostPosted: Mon Dec 28, 2009 7:37 am
I ran compression on 74 225 valiant all are 160psi, ran on my 65 Dart 225 and got 150 on 5 cyl and 140 on one is it time for a rebuild,Also engine on dart sucks for power. Both are automatic.
PostPosted: Mon Dec 28, 2009 8:13 am
Both of them are within spec. I'd first check the timing and give it a good tuneup.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Dec 29, 2009 9:11 am
Check the valve lash as part of the tune-up. (valve adjustment)
Tight lash will throw-off your cranking compression readings.
PostPosted: Sat Jan 02, 2010 2:48 pm
Even if you can't get it any better than that, those are all pretty high numbers. I'd leave it alone until something breaks.
