It is currently Wed Apr 29, 2026 8:55 pm
PostPosted: Tue Jun 10, 2003 8:29 am
My 1973 Duster automatic tranny has no reverse gear functioning. I am told that it will require a rebuild to correct. Does that sound right or are there further checks or adjustments I can make. If adjustments will only last me a couple months, I would rather just rebuild now and get it over with. Thanks for any input.
Mike
PostPosted: Tue Jun 10, 2003 9:23 am
Mike
You need to drop the pan and take a look, the fix could be as easy as tighting the band adjuster, sometimes the locknut backs-off and the lever loosens-up to the point where the activating strut falls-out.
The other cause is blow servo seals, those can also be replaced with-out removing the trans. Pressure test the servo.
The "killer" is a broken reverse band, this happens now and then. The trans needs to be torn-down to fix that problem.
 Post subject: more
PostPosted: Wed Jun 11, 2003 10:24 pm
if the idle is excessively fast when reverse is engaged, it can often result in a broken band.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
