It is currently Fri Jan 02, 2026 8:27 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Tue Mar 18, 2003 11:25 pm
Y'know doc that clean engine block seems to not offer you enough challenges in keeping it running. Perhaps you should send it my way and I'll take it off your hands :P
(I kid I kid)
PostPosted: Wed Mar 19, 2003 8:34 am
I could take you up on that offer, I'm not real happy with this engine.
This is build-up #3 for this block. The current plan is to drop the compression some, the last time around it had 215-220 psi of cranking compression and broke a piston. :cry:
 Post subject: Quick newbie???
PostPosted: Sat May 17, 2003 6:04 am
Does that timing set fit behind the stock timing cover???
Inquiring minds want to know :lol:
Mark K
 Post subject: MP crap
PostPosted: Sat May 17, 2003 8:52 am
As to the MP part no's: one of the sprockets has never, to my knowledge, been available. I believe the crank sprocket is the same as a B-engine. The cam sprocket is a myth, as far as MP parts go. I had that cam sprocket on order for years with no luck.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: Snow Commander...
PostPosted: Sat May 17, 2003 11:21 am
The answer is yes, it fits nicely behind the stock cover....
 Post subject: Cox Brothers?
PostPosted: Fri May 30, 2003 2:40 pm
Do they have a website?
PostPosted: Fri May 30, 2003 6:26 pm
No website at this time..
Phone 614-268-9920
Fax 614-268-9930
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
 Post subject: impending rebuild
PostPosted: Tue Jun 10, 2003 2:26 pm
So if a guy is planning on a rebuild in the fall, this would be the timing chain setup to go with?? -Spin :idea:
Project B-52 Crew
PostPosted: Tue Jun 10, 2003 5:31 pm
Imho------yes
PostPosted: Tue Jun 10, 2003 5:42 pm
The Cox Boys also carry the cast iron double row "roller" chain, that one works well for a mild performance build-up and it is a little cheaper.
For all-out racing, the JP Performance steel gears and multi keyways is the way to go.
PostPosted: Wed Jun 11, 2003 4:50 pm
I'd take the steel set anyway just for the extra longevity in a street engine.
PostPosted: Thu Jun 12, 2003 4:08 pm
Cool, I was thinking the steel set, whilke I've got it apart might as well do it right -Spin
