It is currently Wed May 27, 2026 5:08 pm
 Post subject: Piston ring end gap
PostPosted: Wed Jan 06, 2010 10:12 am
I'm getting ready to assemble my engine.
My Hayes manual says .010 to .020" end gap on the compression rings.
I've measured a few of the new ones and they at were .012"
It's been about 20 years since i've build an automotive engine, but this sounds pretty tight to me.
Can someone confirm what the minimum specs should be? thanks!
The motor's a stock rebuild +.040 sealed power pistons, perfect circle rings. It's going into a pickup.
PostPosted: Wed Jan 06, 2010 10:28 am
They are in range ....<shrug>
Id use them as is. Smart to have checked them.....
PostPosted: Wed Jan 06, 2010 12:13 pm
The Hastings web site has good technical info. http://www.hastingsmfg.com/
PostPosted: Wed Jan 06, 2010 3:26 pm
General rule of thumb is .004" for every inch of bore diameter. Double it for nitrous.
