It is currently Fri May 22, 2026 12:22 pm
Post new topic  Reply to topic  [ 86 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Wed Jan 06, 2010 11:32 pm
The broken piece is the accelerator pump cam. You are also missing the accelerator pump linkage rod that goes from the throttle to the cam. You probably won't get these pieces in your standard rebuild kit and will need to source them from a junkyard, a swap meet, eBay, a carb store, or someone on the board.
See the diagrams on this page.
Awsome I do have the j rod linkage all have to do is get a Carb kit, cam, and I think I found the problem. ...... a piece of silicon stuck inside the Carb where the floater is loc. Ill take a pic and show u guys tomorrow.
68 225 Dart "life under the hood, is the life for me" -By Me
PostPosted: Wed Jan 06, 2010 11:35 pm
Ill rebuild the Carb clean it up. And hopefully come back with good news.
PostPosted: Thu Jan 07, 2010 4:43 am
... I think I found the problem. ...... a piece of silicon stuck inside the Carb where the floater is loc. Ill take a pic and show u guys tomorrow.
Good eye!
Last edited by Kevin Johnson on Fri Jan 08, 2010 11:05 pm, edited 1 time in total.
PostPosted: Thu Jan 07, 2010 5:39 am
Aside: Plenty of carbed motorcycles running around without benefit of accelerator pumps.
But aren't most, if not all of those, variable venturi carbs? That type of carb does not need an accel pump.
PostPosted: Thu Jan 07, 2010 6:00 am
Yes, you're right.
Last edited by Kevin Johnson on Fri Jan 08, 2010 11:06 pm, edited 1 time in total.
PostPosted: Thu Jan 07, 2010 6:16 am
Car Model: '64 Valiant Convertible
But have you put a Holley 1920 on your Honda step thru 90? :lol:
PostPosted: Thu Jan 07, 2010 6:18 am
Site Admin
Nope. Throttle plate opening is not variable venturi. The plate is located below or after the venturi. Slides and other actual variable venturi types, the part opens in the venturi, or choke point.
Fopar is running motorcycle carbs without accelerator pumps with no problem. The carbs he is running are CV's or Constant Velocity carbs. The slide moves based on flow with a butterfly following the slide.
I just sold a motorcycle that had a CV type single barrel that had an accelerator pump. It was a big thumper.
The reason for an accelerator pump is to feed fuel where velocity through the carburetor can drop off to a point that the Differential Pressure at the venturi is incapable of flowing enough fuel from the metering system to maintain driveability. In other words, an accelerator pump is a patch for an engineering problem. :lol:
CJ
PostPosted: Thu Jan 07, 2010 6:43 am
CJ
Great info !
PostPosted: Thu Jan 07, 2010 7:06 am
nice looks like you have it figured out. and the magical chunk of what i call "whats it" that you found doesnt suprize me hehe. happens a lot with 1920 holleys./
PostPosted: Thu Jan 07, 2010 10:54 am
That's very interesting and sounds logical. Be careful about not using RTV silicone gasket maker on carb gaskets. Not compatible with gasoline.
Yea I knew about the silicon thing, but desperate times calls for desperate measures. I needed The Sage running.
PostPosted: Thu Jan 07, 2010 12:17 pm
In a pinch you can make a nice bowl gasket from a really thick paper grocery bag or cardboard cereal box and an X-acto knife.
Last edited by Kevin Johnson on Fri Jan 08, 2010 11:08 pm, edited 1 time in total.
PostPosted: Thu Jan 07, 2010 1:26 pm
I found the pump lever the guy took it of an old carb hand it to me and said $15 is that a fair price.
PostPosted: Thu Jan 07, 2010 1:29 pm
In a pinch you can make a nice bowl gasket from a thick paper grocery bag and an x-acto knife. Had to do that with my old Benelli once or twice.
That so cool! I didn't know that.
PostPosted: Thu Jan 07, 2010 1:54 pm
6 Pack Dart
DO NOT try to use a paper sack gasket for the float bowl !!
The correct gasket is much thicker and is made to seal corectly.
PostPosted: Thu Jan 07, 2010 2:08 pm
Yes, you're right.
Last edited by Kevin Johnson on Fri Jan 08, 2010 11:10 pm, edited 1 time in total.
Users browsing this forum: Google [Bot] and 8 guests
