It is currently Mon May 25, 2026 7:22 am
PostPosted: Thu Jan 07, 2010 8:33 am
Anyone make a 3/8" Mechanical fuel pump ?
If not,is there any tricks/mods to make it 3/8" ?
Seems like having a 3/8" line at least from the tank coming in couldnt hurt.
Thanks.
PostPosted: Thu Jan 07, 2010 8:34 am
Seems like having a 3/8" line at least coming in couldnt hurt.
Yes, but will it help? I have never heard of any slant six suffering from fuel starvation with the stock lines. If you truly need more, you could run an electric fuel pump and the fuel hose diameter of your choice.
PostPosted: Thu Jan 07, 2010 8:41 am
Yeah, I'm echoing Reed's question: Why are you running 3/8" fuel lines? If you're bound and determined, you can put together a fuel pump with 3/8" fittings, but it will be very costly to do so.
PostPosted: Thu Jan 07, 2010 8:51 am
[quote="Reed"][quote="Blown 70"]
[/quote]
Yes, but will it help? I have never heard of any slant six suffering from fuel starvation with the stock lines. If you truly need more, you could run an electric fuel pump and the fuel hose diameter of your choice.[/quote]
Thanks Reed
Going to stay mechanical.
So theres no starvation issues with 5/16" line ?
How about the guys out at the track,all 5/16" lines ?
PostPosted: Thu Jan 07, 2010 10:55 am
5/16" line is good up to at least 13 sec 1/4 miles. Stock pump is good to at 14-15 sec 1/4 miles depending on car wt and HP.
PostPosted: Thu Jan 07, 2010 2:27 pm
The Car is the sig line Runs 14.66 on a stock Fuel System with a 500 CFM Carb.
No Problems.
PostPosted: Thu Jan 07, 2010 5:25 pm
Well there you go...
Thanks guys.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
