It is currently Mon May 25, 2026 6:09 pm
 Post subject: Distributor gear hole.
PostPosted: Thu Jan 07, 2010 5:39 am
So....under normal rotating conditions......does the camshaft pull down on the distributor shaft or push it up as it rotates?
I forget which way the gears are cut.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Jan 07, 2010 9:42 am
Car Model: Toad Wagon
To produce clockwise motion against inherent drag the sum thrust would favor the driven side of the pinion teeth and tend to lift the shaft. At the speeds and loading in operation the tendencies to slide back down from gravitic pull plus the top contact spring pressure and lash back from point squeeze on the lobes wouldn't likely be enough to overcome the shaft inertia involved.
At point float speeds it'd be a slam dunk of course but perhaps at a low enough idle you could get to a neutral balance with a free enough shaft and light enough oil. If so, then with a clear cap and enough axial play you could simply observe the effect first hand.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Jan 07, 2010 12:50 pm
Just set the endplay properly. The idea is to keep it as close as possible while leaving room for oil and heat expansion. This actually matters. It will minimise spark scatter if you keep it at the factory spec. I have set distributers up with less endplay than .007, but not with a nylon gear.
Gear teeth faces that are driving or driven always have pressure between them, otherwise the driven gear would not be getting driven.
What the hell?
