It is currently Tue May 26, 2026 5:38 am
PostPosted: Thu Jan 07, 2010 1:05 pm
Anybody know of a good yet free online dynamic compression ratio calculator? All I can find are ones for v-8s.
Thanks.
PostPosted: Thu Jan 07, 2010 1:23 pm
http://members.uia.net/pkelley2/DynamicCR.html
PostPosted: Thu Jan 07, 2010 1:30 pm
Thanks. Now I have to figure out how to get that program to run on my Mac. :wink:
PostPosted: Thu Jan 07, 2010 1:47 pm
Okay, I got it to work, and I calculated my dynamic stroke length, my cam timing and overlap, and my static compression. But how do I turn any of these numbers into a dynamic compression ratio?
PostPosted: Thu Jan 07, 2010 7:15 pm
Okay, nevermind. :oops: I guess it helps to read the instructions on the webpage. :roll:
 Post subject: Yep...
PostPosted: Thu Jan 07, 2010 7:21 pm
I use that one consistently, and it's a good tool for looking over "future builds".
How'd your engine build turn out?
PostPosted: Thu Jan 07, 2010 7:40 pm
I am finishing up the last few calculations for getting the head decked to achieve an 8.2 dynamic compression ratio.
I would appreciate it if someone could check my math.
I am using the a cam ground to match the Erson RV10 profile. The cylinders are .030 oversize. I have 56 cc combustion chambers (surprisingly they are all the same).
I have calculated that I need 40 cc combustion chambers to bump the dynamic compression ratio from the current 6.9 up to 8.2. In other words, I need to remove 16 cc of volume from the combustion chambers.
Assuming the lowest portion of the combustion chamber is a perfect circle (which I know isn't true due to the factory notched for the valves, but it is close enough), I need to use the following formula to calculate how much I need shaved off:
The volume of the cylinder = pie X radius of the cylinder squared X height of the cylinder
I need to remove 16 ccs, so
16 = pie X radius squared X height
Pie is a constant
16 is a known variable
radius = 3.4 inches / 2 (or, to keep it simple and to keep the units constant, 8.628 cm/2). So, R=4.314cm
So,
Height cm = 16/ (pie X (4.314 squared))
Height cm = .273659058471 cm
So
Height inches = .1077397868
SO! I need to mill .100 inches off the head. Right?
 Post subject: Let's see...
PostPosted: Thu Jan 07, 2010 8:04 pm
Milling the Slant Six cylinder head .0066" gives a 1cc decrease in combustion chamber size
I just would cheat and use Doc's number from the stroker article (It hasn't let me down yet!!!)
so 16CC * .0066 =.1056....
.1077 is on the money...
.100 would be fine...
PostPosted: Thu Jan 07, 2010 8:08 pm
Cool! Thanks Rob! Good to know I still gots my math skills!
PostPosted: Fri Jan 08, 2010 11:37 am
http://www.rbracing-rsr.com/calculations.htm
Here's the one I used Reed.
Cheers!
Al T
PostPosted: Fri Jan 08, 2010 11:39 am
Thanks Al!
