It is currently Mon Nov 23, 2026 6:36 pm
Post new topic  Reply to topic  [ 70 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Sat Jun 14, 2003 4:42 pm
For my birthday this year my family bought me a new Clifford hyper-pak intake. I having been playing with engine combos in my head and I have a couple questions about the hyper-pak. I have heard that the intake runners were "tuned" for maximum efficiency at around 2500 RPM. Is this true? I am building a street motor for a daily driver so the engine will rarely see the high side of 4000 RPM, is the hyper-pak just wasted on a low RPM motor? As far as the perennial "best cam" question goes, right now I plan to put a stock 71-up mechanical cam in the motor (mainly due to kit being the biggest cam I have and my general lack of funds) use .060 oversize pistons and a ported big valve head with Ford 300 valves in it. Does that sound like a decent mild combo to use with the hyper pak or would I be better off sticking with a two barrel until I can afford a more aggressive buildup? I am mainly worried about loss of vacuum at low RPM due to the bigger four barrel intake and big valve head, plus I am putting this in front of an A-999 automatic tranny. Would I be better off saving up for something like a Comp Cams 264S or a MP 268 degree cam? Should i get a higher stall torque converter than stock(the tranny is out of a 1983 dodge van)?
Thanks ahead of time for the help!
Reed
Reed
 Post subject: try this....
PostPosted: Sat Jun 14, 2003 5:30 pm
I am currently running a Hyper-Pak on my drag car.
The set-up runs mid 14s with basically a stock short block, performance cam and a trick head. This lines-up to the performance figures I saw from the days when the H-Pak kit was offered "off the shelf".
This is a ram tuned intake, the idea here is that the pulse waves (harmonic pressure waves) can be used to create positive pressure in the intake track. This happens in a narrow RPM range, my current set-up "tunes" at 4200-4600 RPM, my in car vacuum / boost gauge actually goes positive a couple of psi at that RPM, it is free supercharging. The down side is that this ram effect starts to work against you after 5500 RPM or so, the short runner manifolds really start to work well at the higher RPMs.
A Hyper-Pak is a proven factory designed system that works.
It is great as a street performance set-up as long as you can deal with the cold blooded manners of a non-heated intake manifold.
The factory "tuned" this manifold so a 170 cube road race Valiant could come off a corner strong in the 4000 to 5000 RPM range. Working with cam, carb size, gearing etc, Hyper-Pak combos can be "tuned" to work well anywhere between 2500 and 5500 with super strong
power focused in a 1500 RPM "power band".
http://www.slantsix.org/forum/viewtopic ... t=hyperpak
I quoted Doc (didn't mean to bogart your whole post Doug :wink: )....
And listed the url of the thread, good discussion...
I sit and look at mine, it'll be a while before I goof with the thing. I'll definately want more cam even with stock valves...that thing definately wants to breathe though.
PostPosted: Sat Jun 14, 2003 5:47 pm
Thanks DI. I wiill probably stick with an aluminum Super Six manifold and a staged Holley 2305 until I can learn enough about building hi-po motors to create a strong low-RPM Hyper-pak combo. It sure does look cool though... 8)
Reed
 Post subject: Not hard....
PostPosted: Sat Jun 14, 2003 5:55 pm
66Dart is about to go that route with his dual weber setup, and a OS valve head...(that's going to be a fun ride, but he's got a 3 speed manual...)
All you need is a good cam (Comp Cam 264 looks plenty mild, but much more than what I have...and the 252 is still plenty fun...), Holley 390, proper stall convertor, double roller chain and some 3.21's or 3.55's under your Fish....
PostPosted: Sat Jun 14, 2003 6:50 pm
I don't know what the rear gear ratio is, but is is an 8 1/4. I'll find out when I get it rebuilt. I have an NOS MP double roller gearset and cam advance bushing set, so thats covered. As far as carbs go I have 1920's, a Holley 2200 staged two barrel, a Holley 2305 staged two barrel, a BBD, a 2280, and a Carter AFB but I don't know if it is 500 or 650 CFM. Ultimately I would like to sit the AFB on top of the hyper-pak, since that is what came on them from the factory, but as far as two barrel carbs go I am most excited about trying out the 2305. I just have to figure out how to rig up a reliable cable style kickdown linkage.
I guess once I get done with law school I will have to seriously read up on how to build a proper hyper-pak package for the 1500-3500 powerband.
Reed
PostPosted: Sat Jun 14, 2003 8:04 pm
Hmmm. I have been reading through some of the old posts on this site which talk about hyper-paks and here is what I am thinking right now- since I live in an area that gets below freezing (sometimes) I probably won't run the h-pak with a carb. I will wait until I can afford to spend the time and money doing a proper fuel injection specific slant build (proper head prep like matching chamber volume and compression ratios etc...). Until then I will run the .060 oversize pistons, the Ford valve head, the 71-80 factory cam, the aluminum two barrel intake, and just play around with different carbs on the intake. I should probably get the bodywork done on the Cuda first though...
Thanks for listening to me ramble.... :roll:
Reed
PostPosted: Sun Jun 15, 2003 12:43 am
But turned into an education and more head scratching:?
I have a block on my engine stand( future build) and the matching head attached as a 'dummy'.
I put the h-p intake on it and it was kinda tight to the studs, the triangular washers sure didn't sit right on it...it's like the runners are a bit too fat for the fit.
During the mock up I decided to try and fit a Dutra Front and my modified rear on the dummy also. The exhaust manifolds (both) are kind tight trying to fit them on with the H-P intake in place. I see also I'll have to do some modification of the block and the Dutra Front to get it to seat properly (fit of the front pad is a bit wide, and some interference is encountered with that 'pad' on the block below the head-under the first exhaust port....should I grind that off????)
Talk about learning curve....I think I made up 6 new words tonight!!!!
PostPosted: Sun Jun 15, 2003 9:16 am
Hey, you know, there have been a bunch of questions asked about the hyper-pak. Maybe it would be a good idea to have a continuous thread where people could post their problems and successes using this manifold. Information like that just posted by DI is very helpful to other people. I haven't had a chance to mock anything up yet but when I finally do get around to building up a Hpak motor I will be spend alot of time measuring and trial fitting before I assemble anything permanently. Aside from actual mounting issues (BTW - has anyone fabricated a support for this manifold? Something to keep this loooong piece of metal supported by more than those stufds?) how about any experiences with running different carbs and tuning them? Or would that just be beating a dead horse?
Reed
PostPosted: Sun Jun 15, 2003 9:55 am
As for giving those runners some support, have been thinking of threaded seamless tube with adjstable endlinks, Summit racing and Jegs sells such items. Looks doable. Any other ideas?
PostPosted: Sun Jun 15, 2003 12:26 pm
I have come up with four ideas, none of which I have attempted, and all of which would require fabrication:
(1) since I will be running A/C I have thought about putting a brace between the a/c compressor support and the manifold
(2) building some kind of support bracket that bolts to those threaded holes just above the oil pan rail
(3) building a rubber insulated mount or support which would run between the inner fender and the end of the manifold. THe rubber woudl allow the motor to move but would offer some laterar support for the end of the intake
(4) build some kind of long brace that would run from the bolt-holes in the head to the end of the intake
Ideas one and two seem to hold the most promise. Number three would be a P.I.T.A. to fabricate and might put undo stress on the manifold studs on a torquey motor. Number four woul essentially serve the same function as one and two but would be more complex to make and not provide as much viertical support, so why bother?
My 2 cents... :?
Reed
 Post subject: There is enough room....
PostPosted: Sun Jun 15, 2003 1:20 pm
The two easiest solutions from my mock up experience is:
1) There's enough room to make a bolt on item to close the heat stove on a stock manifold/rear dual....
2) since I live in the northwest, carb heat would be good, so supporting the intake with a pipe welded to the exhaust header would provide a 'heat stove' and support...
I'm lucky to have a large engine bay, having recently 'played' in a 1964 Valiant bay, I have nothing but sympathy for the pre-67 slixer...it's tight in there... :(
PostPosted: Sun Jun 15, 2003 2:35 pm
I was planning on running headers on my slant/h-p combo but with all this talk Im wondering whether or not I wasted my money on the h-p.I would really like to use this intake as i think it would be/ should be a great in take with the right and a lightweight car such as my 60 Valiant.I plan on posting my problems as well as my solutions on this particular project.
Mark
PostPosted: Sun Jun 15, 2003 11:16 pm
Wow, some good discussion on the H.Pak, it looks like there are a few of them waiting to get onto a car.
This manifold does take some work to get installed, doing "mock-up" trial fitting is the way to go. You will have to get out the grinder and make the clearance around the washers and grind the outside edges of the manifold runners to get the clearance you need. Use the intake gasket as a template to be sure the ports are aligning with the head.
As for the support strut, it runs down from the front-lower manifold boss to the drivers side motor mount bracket, there is a hole in it's side where the struts bolts-on.
You can see the top of the strut in this pic:
http://www.slantsix.org/articles/hyper- ... -hyper.jpg
I will get into cam selection and low RPM tuning for the H.-Pak later,...
It's been a long week-end.
PostPosted: Sun Jun 15, 2003 11:23 pm
today I got some mock ups and pics...
I'm specualting due to mass production, QA, and just plain core shift, our H-Paks are going to need a bit of massaging to make things fit all nice....
Here's a nice pic of my spare supersix setup with my soon to be duals setup...it all fit nicely like it was made to go there....
I mocked up the H-pak intake onto my 'test dummy' and put a cardboard gasket on to keep my used head from dirtying up my nice clean manifolds...
I immediately noticed that the runners are a bit fat, and the fit is kinda tight on some of the studs....In some cases getting a triangular washer on might be impossible.....
Duals mocked up fine alone....
Except for the front dual was a bit snug with this boss on the block, I'm going to relieve both parts to get some elbow room in there...
Two major areas developed problems with a 'ground' mockup....
The central runners are so fat, it won't let the exhaust runner with the choke pocket line up....
On the other side, the last runner for Doc's front dual was a bit fat to get in there, it's not the dual, it's the fat-pak....
Tomorrow I'm thinking about getting some marking pen marks on things and grabbing a die grinder and getting some material removed and see if everything goes into place...like the super six....
Food for thought on Father's Day.... :wink:
Had to edit, Doc beat my post. Doc, hope you had a good father's day. I'm looking forward to anything you got for low rpm tuning, if this kinda progress continues, I might be up for an installation in two weeks...would be nice to do it and have something different for the upcoming local mopar show (the row would be The Poehler's and their super sixes, 66 Dart and his dual webers, then one Feather Duster with Dual exhaust and an H-pak......)..... :twisted:
PostPosted: Mon Jun 16, 2003 6:24 am
DI, did all the carb mounting holes come already drilled on your HP? The HP I got only has 4 holes spaced 3 3/4" apart. I'll have to put an adapter on it! What is this 3 3/4 x 3 3/4 pattern anyway, for the old WCFB carbs? An adapter will just reduce my hood clearence. Another question, what should the divider wall between each port on the plenum end look like? I expected an almost straight up and down end on the wall, like other slant six intakes. My center wall is like that, it looks right, and the rest are 'V' shaped, excpt one that is 'V' shaped and with a casting flaw 1/4" x 2" starting at the 'V' and running into the port. And I have some casting slag stuck to the roof of #5 runner that I can't reach with any kind of clean up tool, I don't need it breaking loose later and going thru the motor.
Is it just my HP intake? Or does anyone else have some flaws? Mine may be going back to Clifford, I'm a little disapointed. :(
Cecil
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
